Alarm installed and won't work...?
Old May 7, 2005
R1Style's Avatar
**EDITED** Check out page 2
Old May 8, 2005
R1Style's Avatar
Somebody has to know....
Old May 8, 2005
bngu1's Avatar
bngu1 is an unknown quantity at this point
make, model, year of vehicle you're working on
Old May 8, 2005
R1Style's Avatar
03 LX coupe
Old May 8, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
DEL*
Old May 8, 2005
profuse007's Avatar
Senior Member
you need to label which is which, #1 is lock or unlock, 2 is lock or unlock???
Originally Posted by R1Style
NC-----Orange--------------- (picture of scissors)
COM---White----------------- OFF Signal
NO-----Yellow---------------- Ground
civic door lock required negative trigger. input ground to COM(30), and output NO(87) to doorlock (lock or unlock).
NC-----Orange/Black---------- (picture of scissors)
COM---White/Black------------ ON Signal
NO-----Yellow/Black----------- Ground
Where do I tap the White and White/Black wires to according to the DIY?? CLICK HERE
dont understand what youre stating here. that link is not the DIY, my DIY is somewhere in the DIY section or check my sig for the DIY on civic.
Also... for the Door Trigger... what is *2 ????? What color wire am I looking for?
*2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white.
youre lookin for all of those wires, use diodes to isolate each triggers.
Old May 8, 2005
R1Style's Avatar
that's the thing... I don't know... the way I drew it out for you is the way it's shown in the installation booklet as the negative trigger.
btw I'm not installing a Viper alarm... it's a Huatai HT800A Link
is this for the viper alarm cause you lost me.
aight cool.. I just didn't know what *2 meant...
Old May 8, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Why do you do this? What happens if you don't?
Old May 8, 2005
profuse007's Avatar
Senior Member
for whatever reason why they designed it like that, iono. but if its given individual trigger, you need to isolate them for its sake of principal. technically speaking, to leave everything stock as possible in everyway and not to alter any of the electrical design.
you can get a single trigger that catches all door at the guage cluster.
Old May 8, 2005
profuse007's Avatar
Senior Member
scan me the install manual and ill interpret it for you.
or just starting using a DMM, which is easier, and test whats pulse is sending out.
Old May 8, 2005
skipbarber's Avatar
your key-in or parkinglights indicating beeper will be triggered by all doors if you dont isolate this wire. You know that warning that goes off when you open the drivers door when you leave your lights on? if you dont diode isolate them, you can open the rear passanger door and it would trigger the indicator.
Old May 8, 2005
R1Style's Avatar
Here you go...
Old May 8, 2005
profuse007's Avatar
Senior Member
UNLOCK(assume OFF is equivalent to unlock)
white-to civic unlock wire
yellow-ground
LOCK(assume ON is equivalent to lock)
white/black- civic lock wire
yellow/black-ground
Old May 8, 2005
R1Style's Avatar
Thanks... hopefully that works. +1rep
Old May 9, 2005
sador's Avatar
sador is an unknown quantity at this point
Door Trigger colors!
First you must isolate the wire from each door,you need to use a diode 1 Amp (1N4004 or 1N4007) Cathode (Band) Side Of Diodes Face OEM Wires,you can get these at Radio Shack.
Driver door=green
Front passenger door=Lt green/red
Rear Doors= Green/white
You can get this wires from a green plug under the steering column on your left (This plug should have a tape around on it) if you don't have an OEM alarm.
Plus theres some other helpful wires on that plug ready to be use for alarm like Trunk Pin,door locks,parking lights,Power,etc.let me know if you need more wiring code and some info about it.
A friendly advise from an Pro Installer.
Good Luck
Old May 9, 2005
R1Style's Avatar
ya totally lost me.
What does the diode do and why do I need it?
Is it because I need to tap the one alarm wire into two seperate door wires?
Old May 9, 2005
CraigW's Avatar
A diode is sort of a 1 way gate of sorts it has an anode and a cathode (marked on the package when you buy them BTW) these are used to prevent signals/voltage from one section or circuit from feeding signals/voltage to another circuit.
A diode will allow voltage to pass one direction and not the other.
Please observe polarity (anode/cathode) when hooking up
Old May 9, 2005
R1Style's Avatar
aight cool... actually that info helps a lot.
Thanks.
I'll get the reps around once it allows me to.
I really appreciate the help
Old May 9, 2005
sador's Avatar
Arrow This is what you have to do!
This is what you have to do my friend
Good Luck
Old May 12, 2005
R1Style's Avatar
Thanks for the diagram bro! btw... where is the door trigger wire? Couldn't find it last time. Where exactly is it located/beside?
btw... just got a new alarm... returned that other one and I got a Compustar 2wfmas.
Old May 12, 2005
profuse007's Avatar
Senior Member
lcick on my sig>tutorial
Old May 12, 2005
R1Style's Avatar
ok my new alarm diagram... can someone explain which wires on the CN2 plug go into where on the car? Light output... Status output... wtf are these?
btw... what's the jumper for? I have an Auto so I'm guessing I have to cut it.
2000 points and rep points for whoever helps me... profuse i'm looking in your direction
Thanks!
Old May 12, 2005
sador's Avatar
Talking CN2 wire code mean!
#1 Light Output = go to you red/black wire for your parking lights
#2 Status Output = is to connect an Transponder Bypass for our cars "is a most part that you need" like 555U,555I or 555H from DEI or other brand to bypass our keys in order to our cars start.
#3 Ignition Output goes to the Black/Yellow under the Steering Column
#4 Accessory Output goes to Black/Red Under the Steering Column
#5 Starter Output goes to the Black/White the Steering Column
and the door trigger you can foud it on the right side of the steering column on a green plug.
So good luck and another friendly advise from a Pro installer.
Old May 12, 2005
R1Style's Avatar
Thanks... but I guess what I don't understand is that plug CN1 has the same wires as CN2.
So do I put:
CN1 - #2wire and CN2 - #1, both on the red/black parking wire?
CN1 - #7wire and CN2 - #3 on black yellow ignition?
same with CN1 and CN2 for accessory and starter?
Am I making any sense?
Old May 12, 2005
sador's Avatar
Thumbs up CN1 and CN2 are not the same
My bad I didn't pay to much attencion to CN1, CN1 is fine ,But anyway you have to use only on CN2 Ignition Output with a relay because our Civic has a second ignition,and the Status output to the transponder bypass.
You need a Relay and you have to conect it this way
#85 to Ign One (Black/yellow) under the steering wheel
#86 to Gr #3 from your alarm
#87 to the 2nd Ignition Black/Red
#30 to +12v
Good Luck
Old May 13, 2005
R1Style's Avatar
#30 to +12v
Good Luck
Ok gotcha... thanks for the help!
Old May 13, 2005
profuse007's Avatar
Senior Member
use parking light on CN1
status, ign, acc is PRETTY much the same. starter, only Nissan needs this for 2nd starter.
Old May 14, 2005
R1Style's Avatar
Thanks
Old Jun 1, 2005
R1Style's Avatar
Edit: Alarm installed by a PROFESSIONAL and it still doesn't work.
The remote doesn't communicate with the brain.
Old Jun 7, 2005
R1Style's Avatar
Anyone have any ideas?
The installer said I might have pinched the antenna wire... low and behold I did. So I cut out the section of wire that was pinched and reconnected the wires but it' still not working.
sjonesd3
Jun 11, 2015 06:32 PM
MamaBear2015
May 18, 2015 07:37 PM
Laurenhunter7
May 10, 2015 01:09 PM
Linda0818
Apr 23, 2015 11:30 AM
loquito
Nov 12, 2001 07:24 PM
