Reset ECU after Intake/Header/Exhaust???
Old May 5, 2005
XtaGy's Avatar
XtaGy is an unknown quantity at this point
All the mods mentioned above were installed with the battery cable connected, and my gas mileage has plummeted ever since. The needle moves very fast and is no where near where it was from factory. Am I missing something? Do I need to reset the ECU for it to "learn" the new upgrades? Please advise...
Thanks,
XG
Old May 5, 2005
djmota's Avatar
it will fighure it out after some driving. but reseting it will make it learn faster.
reset the ecu and let it idle for 5 minutes or so. then drive it around.
Old May 5, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
yea... cause if anything you should gain 1-2 mpg or so from those mods. our stock exhaust is rediculously restrictive. reset it and you should be fine.
Old May 5, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
this is prolly a stupid question,but how do you reset the ecu?
Old May 5, 2005
djmota's Avatar
under the hood, take off the fuse box cover and pull the ecu fuse for a minute or so.
Old May 5, 2005
Ashhole's Avatar
thats it? seems pretty simple, thanks.
Old May 5, 2005
acidbaby's Avatar
The Beez Kneez
or disconnect the neg. batt connection....02
Old May 5, 2005
Civicious's Avatar
Civicious is an unknown quantity at this point
That's what I would do....
Old May 5, 2005
i thought all the fuel maps were hard copy in the ecu? And the reset was only for idle learn.
Old May 5, 2005
Ashhole's Avatar
thats what i thought too, but i have also heard that you can reset the ecu to try and get a little more power and beter feul mileage
Old May 6, 2005
Sdcivic549's Avatar
Sdcivic549 is an unknown quantity at this point
The hard fuel tables are only at WOT I think which is open loop mode(?)
Old May 6, 2005
Jrfish007's Avatar
Well, it's not really a hard table, think of it as a 3D graph. The ECU must know three things, it will plug those into an equation and out pops the A/F ratio. It can adjust the A/F and I think ignintion (not sure about the 7thgen civic on the ignition though). What can happen with all these mods, is sometimes you can send a sensor off on some weird loop and resetting it usually the easy way to fix it.
You may want to check to make sure all the sensors you've moved are okay visually too. The CAI can sometimes screw with the thermocouple so the car can not see what the inlet temp really is. May want to look at that, then check the O2 sensors.
If a reflash doesn't work and all the sensors look okay, take it to AutoZone or something and have them plug it up to a computer and look for weird readings. I had an O2 sensor on my old truck once that was reading really high numbers, but since it was reading high numbers, the ECU didn't think it was bad, instead it though the engine was running lean and started dumping more fuel into the engine. Changed the O2 sensor and all was fine.
Hope that helps
Old May 6, 2005
Jrfish007's Avatar
But then you have to reprogram the radio
Old May 6, 2005
djmota's Avatar
Hope that helps
good explanation +1
Old May 6, 2005
paradoxblue's Avatar
try kicking it?
Old May 6, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
THat works... I also like to crank it with the fuse pulled... Lets me know its reset.
Old May 7, 2005
Jrfish007's Avatar
good explanation +1
Thanks I have some Electrical Engineering friends that work on HVAC systems on cars... That's how I know
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
lowlife9
Oct 6, 2015 04:39 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
ttamrekab
Sep 28, 2015 01:22 AM
