- 03 Cluster Conversion (Q's) If you own a 03+ EX Please look!)
- dose anyone know???
- factory plugs
- power window problem
- exhaust questions
- Is there a problem with my car??
- What Nexted??
- Does DX catback fit EX?
- breaking honda bond???
- Compression Ratio
- can you bondle urethane side skirts to the body of your car
- 04 Vp clusters
- does anyone know how to remove the side door panel
- Does anyone know how to remove the side door panel
- installing new gauges
- Installing an aftermarket CD/DVD Deck
- I.D. of fuel feed line?
- question on 04-05 fog lights
- Slight idle wierdness.
- 04 ex where's O2 sensor located? pls help me out
- 2002/2003 fit on 2004 ? or swap
- Exhaust pipe diameter
- replacing dome light..
- o2 sensor size?
- Transmission Fluid Cooler Help!
- Looking For Wheel Well Lights?!?
- Cam shaft swap?
- Coupe exhaust on a sedan? YES
- Throttle Positioning Sensor problem.
- DIY Aluminum floormat
- Gauge cluster problems
- where's my distributor?
- newbie question (air silencer)
- Interior Dome Light - '02 Civic LX
- small dome light
- brake light rattles
- airbox
- Question about engine blocks
- P0401 EGR Flow Insufficient Detected
- Gauge Cluster
- Transmission Slip
- Enzo doors
- srs light aghhhh!
- Silicon on headlamp/XENON corners?
- 2005 LX with rocking front drivers seat
- Unichip Piggy Back ECU
- Hondata ECU-Show Support
- Automatic Trans Fluid Change
- '02 Civic Automatic Transmission Fluid Change
- S2000 Guage
- Wheel Wall Lights
- Tightening Cable Problems
- DIY Custom Turbo
- M3 power mirror wiring help!
- new tires
- Reseting the SRS Light in an 01 Honda Accord??
- side mirrors
- MSD ignition
- How to change the lights on buzz sound
- i need some help
- 2002 and 2003 gear ratios
- Speed Governor
- Stock exhaust hangs to low....
- 01 aftermarket grill
- RSX Cluster
- Is it possible/worth it? (gauge cluster question)
- question
- Would anyone be interested in Eagle Rods
- Hey I got a ?
- doble spring on valve!
- Question... =-)
- Help! Where Is This!
- what is this censor?
- what is this sensor?
- Hp Full Race Header
- when getting cams installed...
- '91 CRX trans in a '96 Civic?
- Denzo Uridiums (spark plugs)
- Shifter
- Painting the bumper grille inserts
- Best type of non-synthetic oil for a So Cali 2k2 owner?
- Sanding plastic?
- Drum to disc brake conversion?
- Trunk wrap DIY?
- Calling Diy Gods )( Buttons!
- VAFC Controller insructions
- Question about 7thgen's Ignition System?
- LX exhaust on an EX...questions
- More range for radar detector
- cel light - megan test pipe - my 03 ex
- Eibach Sport lines HELP
- Installing Mugen COld Air Intake Help!
- Removing the rear bumper!
- How many watts
- Bumper Damage
- seatbelt buzzer
- Who has an aftermarket steering wheel?
- Cheap Mods for Hp Gains
- Factory Headlights
- Rwd
- Lsd
- hey i forgot what part num for bulb!!!
- can't see my gauge needles
- t3/t4 turbo
- Something to make the Civic run better= Sea Foam
- Could you wire your high and low beams together?
- AEM short ram intake
- high beams
- Turn signal bulbs
- Functional Tunnel ram
- Repair Manual "PDF" version
- why does this happen?
- Torque specs for manual tranny fluid change?
- relocate oil filer
- Installing Venom400
- removing washer fluid reservoir?
- Port & Polish... worth it?
- taking my car to the shop
- saturn turn signal conversion?
- OEM fog light install?
- Shock Trunk
- Exhaust Installation Question
- Interrior paint
- Buying the Revo SS
- head swap question
- Swapped Immobolizer
- New Exhaust
- Hate HOODPINS?? Look in here!!!!!!!!!!!!!!!!!!!!!
- Shift boot squeaks.........anyone else?
- Bosch Oil Filter Life?
- Jerking/Sputtering
- How much does a valve clearance adjustment cost?
- Fuel Filter?
- high idle problems?
- Air Horn DIY?
- Cold Air Intake DIY
- blown intake manifold
- How do you remove trunk??
- Awakening from hibernation
- Complete Build up with turbo question.
- slow off the line
- those of you with honda service manuels...(please come in..)
- A little help guys!!--where to set boost controller
- differences between ex and lx
- S2000 HID in OEM headlights??
- Coolant 101
- DIY: [Easy] Ignited Push Button Install
- Jump Starting Another Car.....
- Front Strut Bar; Neuspeed
- RSX Steering wheel questions
- Exhaust rattle.....suggestions?
- clearing headlights
- Srs Light ?
- LED question
- how do they work?
- headlights.
- Good Battery?
- HID install (Clean up) Help
- fluids
- custom LEDS
- s2000 steering wheel
- Torque vs. horsepower
- What type of intake?
- vtec dis-engaged?
- Speed Governor
- Funny noise coming from trans
- Help getting a OBDII Reader thing
- Help! o2 sensor prolbem
- Torque Specs for TB???
- Help With Specs!
- Quick Question about Battery Cable Information ( Parasidic Drain Test )
- E-brake
- Where is the starter located?
- Paddle shifters
- What is the Difference between HX/EX???
- P1457 error code
- "Cold"air intake through headlight in progress w/ pics.
- initial setup for v-afc
- Location of throttle cable
- Oil Change
- custom V2 intake
- ex header to lx
- Rumbling Exhaust
- Clutch time folks
- !!!!!!!!!!!HELP !!!!!!!!!!!!!!!!!!!! :cy:
- Ebay: DC5-R Injectors
- Help???
- lights behind the a/c controls
- Engine Light???
- Holy Fu@#!!!!! Hydro Lock???
- bigger fuel injectors?
- sans passanger seat...
- Brakes?
- Sqeaking Brakes
- Front Suspension Q
- Silicone Adhesive
- Lx to Ex header/cat conversion
- Is there a way ?
- Help With Valve Adjustment
- vafc settings
- Push Button Start Help
- Brake Bleeding Pattern !! Urgent
- Torque on šPlugs
- The D Series Engine?
- Looks familiar!
- Help qUICK
- coupe headlights in sedan.
- NEED HELP on removing rear dash board
- Can torque converter be removed/installed w/o dropping tranny?
- Cluster question
- what kind of welder needed for exhaust and headers?
- M3 type mirrors How to Wire?
- rear lip problem
- Muffler rusting
- spark plugs
- oil cap and radiator cap fitment
- Dyno Results for ALL products?
- HP wise, whats the best I/H/E combo?
- To cut or not to cut
- HEY GUYS! Newbie Questions??? Sorry
- One question about coolant flushing?
- Altitude
- Clutch Install Tricks
- Advanced Timing
- HP With new mods???
- Intake poping!
- how to do oil change?
- Car not starting if not in 'Park' completley
- Matinence Req Light
- DIY needed for Radiator flush and fill
- Replacing timing belt... help!!!
- What is the output of a Civic stock alternator?
- Throttle Cable Installation who has done it?
- i hit 10k miles
- Shift Points
- Redline MTL (MTF) and spark plugs?
- DIY.. Reducing Weight in Door Panels
- Exhaust bushings
- Earls Plumbing
- Braided Line Fittings?????????
- Help with REVO SS install
- Transmission Coolers?????
- Oil weight question!!!!
- Spoon Thermoswitch
- VAFC-II Whats your Tunning??
- Fiberglass boxes??
- RSX center console into Civic 2dr?
- Sounds like water stored in my engine bay
- Micro Polishing??
