Help! o2 sensor prolbem
Old Nov 14, 2004
civic2uner's Avatar
I recently decided to take my engine back to stock and while putting the stock intake back on I forgot to put the o2 sensor back in. what are the damages of this and what are some of the prolbems this might have caused? I have drove it for about 2 tanks of gas before i noticed it.
what do i need to do to correct it? just plug it back in and reset the ecu?
Old Nov 14, 2004
civic2uner's Avatar
anyone? i need help on this today.
Old Nov 14, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
theirs no o2 sensor on the stock airbox, but their is an air temp. sensor that plugs in the airbox (the actual box with filter in it) that is located right above the TB.
Old Nov 14, 2004
civic2uner's Avatar
either way, the thing was left unplugged for about 600 miles. any damage? do i need to reset my ecu after plugging it back in?
Old Nov 14, 2004
D17thgen's Avatar
no damage that i know of. plug it back in asap (you can reset ecu if you feel like it but dont see why you should)
Old Nov 14, 2004
Didn't you notice the check engine light coming on? But it doesn't really matter. That sensor doesn't really contribute much to the ecu adjustments. If the temp gets really hot o really cold, it may change the a/f ratio, but not by much. Plug it back in, and reset the ecu so the check engine light goes off. If you still had the plug connected and the sensor was just hanging out in the engine bay, then the cel would not have come on and you can just put it back in the intake.
Old Nov 14, 2004
MegaHurtz's Avatar
how do u reset the ecu?
Old Nov 14, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
Take the negative battery terminal off for 15 mins
then start the car.
Old Nov 14, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
yup.. i have mines off right now and been driving around with it off for about 1000miles
Old Nov 15, 2004
4jacks's Avatar
then start the car.
Old Nov 15, 2004
civic2uner's Avatar
could this being off affect you gas milage?
Old Nov 15, 2004
4jacks's Avatar
If it increases your air/fuel ratio then yeah your gas milage will go down a bit.
quit being lazy, and go plug the thing in
Old Nov 15, 2004
yup.. i have been driving around with it for a while cause my custom intake has no place to plug it in
Old Nov 15, 2004
4jacks's Avatar
Get a $16 intake off of Ebay, and use the mounting (gasket rubber thing) you'll just have to drill the hole, to whatever size, you should be able to measure off of the $16 intake.
It may be possible to use the mounting gasket thing off the stock intake, I haven't looked at it.
Old Nov 15, 2004
dont need it.. i already have the rubber gaskets... just took off the piping today and put my AEM back on.. sold me turbo so as of now i am no longer boosted
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
