spark plugs
Old Nov 3, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
spark plugs
as the title says.....
anyway am wondering on where and what are the part number and heat range of what spark plugs you/anyone uses
aftermarket, OEM, higher heat range/lower heat range....
i am still on the OM ones from the factory and am wondering on what you guys use....
thanks....
Old Nov 3, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
well 1st for ur sig... i think autos are HELLA FAST
I will soon run Spoon Plugs...$110.00 by next Saturday
Old Nov 3, 2004
kikoy's Avatar
what's the part number?
Old Nov 3, 2004
civictuner's Avatar
it is SPON0023
heres a link: http://www.inlinefour.com/spoonirracsp1.html
will fit all motors D-B-K-F-H series
Old Nov 3, 2004
www.sparkplugs.com
NGK Iridium IX
Imo, these are way better than stock because of a lower voltage requirement. They also take more abuse without fouling out.
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
$110 for spark plugs???????? ... you're ****ing nuts
and I thought denso iridiums were bad ...
ngk iridiums
Old Nov 4, 2004
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
spending more $$$ for sparkplugs on a stock d17 is very good way to throw your money by the window(like we say in french...integral translation)...keep NGK platinum...keep the difference for other mods that will give you real performance...tires,suspension and brakes...or bring your girlfriend to restaurant and have a hot night after
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
agreed. this plugs are for RACE CARS ... you (civictuner) do not have a RACE CAR
"Ever wondered what spark plugs Spoon uses in their race cars?" -website
Old Nov 4, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
just out of curiousity , I know it's sort of of topic, but what gap do you guys run, or for that matter what is the stock plug gap spec???
Old Nov 4, 2004
We run stock gap, and it's in your owner's manual.
Old Nov 4, 2004
Logan3024's Avatar
Kikoy you forgot to mention your running a 75 shot. stay away from platinum, and get ngk copper plugs, you should be replacing them often if you spray alot, and these are real cheap. Id also recommend you reduce the gap slightly over OEM, depending on if you spray alot
Old Nov 4, 2004
Yup. If you run nitrous or turbo, stick with the copper.
Old Nov 4, 2004
CivicHX01's Avatar
i'm runnin denso iridium ik20
i'd say run a bit colder than stock if you spray a lot...
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
