saturn turn signal conversion?
Old Nov 22, 2004
In case you don't know, the newer saturns have turn signals that stay on all the time and flash when the signal is used. It's one bulb and one intensity. Now I was wondering if there is a way to wire civic turn signals so they come on with the parking lights but blink on/off when the signal is used instead of just flashing brighter. I don't have any idea how, but it won't work just by switching the bulb from 7443 to 7440. Then they will ONLY light up with signal. I want them to stay on with parking lights and then flash on/off completely when signal is used.
Old Nov 22, 2004
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
This is just an idea, but what if u tapped into the parking light wire and then tapped into the turn signal wire and connected the wires with a relay. That way, when the turn is turned on....the relay will kick in and give the turn signal wire a complete connection which will make the bulb blink. Its just an idea because Ive been thinkin of a way to wire my side mirrors like that where they would stay on with my parking lights and then blink with my turn signals.
Old Nov 22, 2004
Well if you just want the mirrors to blink AND stay on with lights, you just tap one wire to parking light and the other to signal (no ground). When one is on, the other acts as a ground. No need for relays. But this is different from what I want.Oh and wiring this way will make the mirror signal blink alternately with the front signal.
Old Nov 22, 2004
scrimp's Avatar
Hmmm cool thanks for that info. It would be interesting to know how saturn has done this.
Old Nov 22, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
id be careful about aspiring to be like a saturn :P
j.k sounds like a cool mod
Old Nov 23, 2004
04RedCiVP's Avatar
Every predator is someone elses prey!
04RedCiVP is an unknown quantity at this point
Isnt that how the 04-05's are? Maybe Im confused?!
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
