DIY.. Reducing Weight in Door Panels
Old Oct 30, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
i did this cause i was bored on my 2004 Civic Coupe..
ok here it is..thought i should do something on this forum since ive been here so long
Diy...Reducing Weight in Door Panel
1.Remove the door handle...u have to pop a tiny panel to revel the screw
2.Remove the rod
3.Remove the power window switches...theres a tiny panel to revel the screw
4.Pull it out and behind it, it will reveal 2 more screws
5.Now u should be able to pop the door panel out
6.Ok, now it's out
7.Flip the door panel upside-down so it will reveal all the foam blocks
8.Ok pull out all the foam blocks
9.Now the door panel should be some what lighter
10.Now reassemble the door panel
11.Presto, lighter
12.The door open and closes lighter now!!
Old Oct 30, 2004
civictuner's Avatar
What u think???
Old Oct 30, 2004
Akutenshi's Avatar
The Rizing Sun
lmao. nvm my post
Old Oct 30, 2004
abmerop18's Avatar
Jam out with your clam out.
wow. you saved a whole .25 lbs and now your door is gonna rattle like none other. congrats
Old Oct 30, 2004
civictuner's Avatar
i did it 3 months ago and it never rattled...even over rough terrain
Old Oct 30, 2004
civictuner's Avatar
and if it did you could always hot glue it back on (WHICH I HIGHLY DOUBT WILL EVER HAPPEN)
but rattling that is totally Honda put it there for reninforcement so the panel wont come all sluggish but it felt the same after i did the DIY..nice and stiff
Try it...
Old Oct 30, 2004
Yeah honda only puts that foam in for crash protection. Stupid circuit city took em out when installing dynamat. It's better to have them on.
Old Oct 30, 2004
civictuner's Avatar
really.....how can foam help?? it is like sticking to the door and when the door get in a accident the panel could just pop out and hurt u..while now..with the foam removed there is this air gap and now it will take a serious beat to the door to make that panel push out..and if it does it wont fly out making it less likely for you to buy a new panel because the old panel cracked or something
by the way..that is why there are the side bars in the door.. that is the only part that protects u in the event of a side collision
Old Oct 30, 2004
It's impact foam, that's why it's so dense and hard to squeeze. Just like there is styrofoam beneath the front and rear bumpers.
Old Oct 31, 2004
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
You registered in June 2004. That is not a long time.
Old Oct 31, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
when i first readt the topic it said LIGHTING... so i was thinking u somehow added lights to the door or something... after further investigation it seems it was wactually door LIGHTENING..lol
Old Oct 31, 2004
civictuner's Avatar
impact foam on doors panels?? wont that cause more injury because the force of a impact could punch that sucker out but then again w/o the foam there is relativly no worrys or less damgae done to panel
Old Oct 31, 2004
civictuner's Avatar
is any1 gonna do this
because when u slap on a fat intercooler u take out crash support so what does the foam in the panels provide NONE!! because the side beams is what protects u
Old Oct 31, 2004
Yeah I really don't care about little crash stuff. Mine are out anyway and the styrofoam is cracked from taking off the bumper. If someone hits you, a piece of foam isn't gonna help you or the car much. Maybe it helps for sound deadening tho by covering those big holes.
Old Oct 31, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Noone is gunna do this Are you dumb????
You only got 3red dot's your doing good on the site keep up the hard work
Old Oct 31, 2004
Bires's Avatar
Bires is an unknown quantity at this point
I'm actually planning on increasing the weight of my doors by packing them with sound dampening material (felt padding and Cascade VB2). I like the solid feel.
Generally, for every 10-15 lbs of weight you add, you lose 1 hp. So, be adding 10 lbs of sound dampening material to the doors and side panels, I'm only going to lose at most 1 hp, and it will cut down on road noise/midbase reflection.
Old Oct 31, 2004
dirtySAMURAI's Avatar
I log in from time to time
^^ HP doesn't mean much in our cars. They're slow from the factory, and after you modify it, it's still slow.
Old Oct 31, 2004
civictuner's Avatar
not really get a full exhaust systen a a k&n drop in w/ some tubing and u can make a auto ex run 16.5
Old Oct 31, 2004
civicvtec1ps's Avatar
Search and Learn
16.5 is fast to you?
Old Oct 31, 2004
civictuner's Avatar
well for a auto yeah.. i mean ppl been sayin there is no way to make a civic run faster.. and well 17 sec to 16.5 IS PRETTY GOOD especially is a fukin auto
Old Oct 31, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Wow... 16.5... I'm impressed... Maybe with a few stickers it'd be down to 16 flat... Seriously, those foam pieces are there for a purpose. They are a sound dampening material, along with being a side impact precaution. To say they do noghing in the event of a crash is ludicrous. The panels will not pop-off without them in there? Umm... ok, they are there to absorb the impact between the door skin and the door panel. That is their purpose.
Old Oct 31, 2004
Mr.Modify's Avatar
omg...worst thread evar
Old Oct 31, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
The foam helps i'm sure. If you remove the foam from under your front bumper you wont pass vehicle safety inspection. It's structural foam for impact dissapation.
And why the fu(k would you want to go through all that just to save like 2oz. I think if you just took the time to do that install and instead walked around your block you'd not only lose 2oz you'd also be healthier
Old Nov 2, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
I did a full body lightening on my 'Vic, and now run with no doors, side or quarter panels, trunk lid, hood, or roof. Yeah, I'm definitely pimping it now, gentlemen. I'm pulling at LEAST 15.7 on the track, but hey, I only use a little metronome to time it so I guess that's mostly a guess. You guys should really try throwing away 3/4 of your car, and get rid of all that stupid "safety" stuff... IT'S HEAVY!
I was doing 16.0 for a while, but then I went down to the parts store and picked up neuspeed, AEM, injen, MoMo, and a few other types of stickers and affixed them to my bare frame. Now I'm riding low and fast, baby. You'd be surprised what a difference steal-me-stickers make, even on a vehicle with no mods! (I mean, other than stripping it down to the frame, of course LOLOL!!)
Old Nov 2, 2004
bakuretsu's Avatar
This is a terrible thread.
Old Nov 2, 2004
ncirom2003's Avatar
the foam is more for when you lightly tap a car while parking...(not that i do this lol ) its so you bumper will bounce back not indent and its also so you dont feel a real sudden jolt.. you feel less because the "impact absorber" (foam) absorbs it.... as for the door foam if anything its just for less vibration maybe i dunno but its def. not for impact because the panel could pop off easy and if u get in an accident where they reach that far in the door you have bigger worries... but w/e i still dont see why to take it off...
Old Nov 2, 2004
cambo's Avatar
I wish I was asian
you'd lose more weight taking a pooper before you got in the car than doing this craptastic DIY.
Old Nov 2, 2004
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
the foam weighs nothing, this is the most rice idea ive ever heard! honda put it on for a reason, leave it there!!!
Old Nov 2, 2004
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I'm all for weight reduction, but I'd have to agree with everyone else. Foam is only a few ounces. Now removing it in conjunction with the entire door panels and their contents would be more reasonable to me. Maybe save 5-10lbs per door that way. Now remove a whole bunch of other things around that same weight and you'll find it adds up quick and can make a significant difference in acceleration, braking and handling.
A few ounces are not gonna make a difference.
Old Nov 3, 2004
ohiojosh78's Avatar
fill your tires and interior cabin with H2
