03 Cluster Conversion (Q's) If you own a 03+ EX Please look!)
Old Dec 14, 2004
ry's Avatar
ry
darkness
ry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of light
I put the 03 gauges in today, everything seemed to be fine but there are two issues now:
1. When the headlights arnt on the gauges are very bright, but when i turn it once or twice they get dim (as well as the interior lights)
2. My battery is dead. I am hoping something shorted while I was putting it together and killed the battery, not that there is still a short .
Can anyone with an 03+ EX verify that is how the lights are supposed to work? I think the battery solution is unrelated.
Another thing is the gas seems to make a slight clicking sound for a few seconds (like its trying to go down and cant anymore) then it goes up to normal, is that normal?
Old Dec 14, 2004
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
Damn man wish i knew what was up....your gauges worked perfect in my car thanks again
Old Dec 14, 2004
ry's Avatar
ry
darkness
bump, haha
Old Dec 14, 2004
The gauge needles should click when the car is turned off.
On the newer clusters, the gauges stay lit when the lights are off and dim when you turn them on. Have you played with the dimmer ****?
Old Dec 14, 2004
ry's Avatar
ry
darkness
Ok so they are supposed to be like that, good, just wanted to make sure before i start putting **** back together.
Yea the dimmer **** works fine but it doesnt save the settings once you turn the car off...
Old Dec 14, 2004
Ya that's one thing I don't like about it. They made it hard to see during the day, so that's why they have them light up really bright. Accords are the same way.
Old Dec 14, 2004
ponyman's Avatar
ponyman is on a distinguished road
Actually on the 03+ gauges there are two settings for your brightness. If you turn your headlights on you can adjust the brightness for when you headlights are on, if you turn them off then you can adjust the brightness for when they are off. So it gives you the option of how you would like it set up.
Old Dec 14, 2004
ry's Avatar
ry
darkness
Mine doesnt save the settings once the car is off though... oh well.
List of problems to fix:
"Cruise" Icon comes on for about 5 sec when car is first started.
A key icon come on when I turn cruise control on.
Stock cdplayer no longer works
Keyless entry doesnt work.
Got a jump and let her run for abit hopefully all is well now...
Old Dec 14, 2004
Interesting. I know keyless and deck were tied together in older civics, and I have no clue why the gauge cluster has anything to do with it. The key icon is the immobilizer and normally stays on if the wrong key is used and the system is active (disables starter).
Old Dec 14, 2004
ry's Avatar
ry
darkness
I had the wires swapped for Cruise control and immobilizer, fixed.
I replaced a fuse under the hood labeled "backup" and cdplayer/keyless works.
Next problem, my cdplayer isnt accepting the code inside the glovebox, wonderful!
Old Dec 14, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
one mine when i was replacing the deck. i found the code on the deck it self. I was like wtf!
Old Dec 15, 2004
ry's Avatar
ry
darkness
Argh my battery is dead again...
and the door keeps shocking me
Old Dec 15, 2004
Logan3024's Avatar
post some pics
post up a diy
and post where you got your cluster from, thanks
Old Dec 15, 2004
ry's Avatar
ry
darkness
Originally Posted by DIZZLE
post some pics
post up a diy
do you not understand my car wont start? lol
Old Dec 15, 2004
joshb_'s Avatar
Boosted 04
post some pics
post up a diy
wtf..lol
Old Dec 15, 2004
ry's Avatar
ry
darkness
replaced battery, car starts, power windows/sunroof dont work and cdplayer isnt accepting the unlock code...
Old Dec 15, 2004
code might be wrong
check all fuses
Old Dec 15, 2004
ry's Avatar
ry
darkness
code might be wrong
check all fuses
Im using the code on the glovebox... going to check fuses now...
Old Dec 16, 2004
ry's Avatar
ry
darkness
problem solved, it was a fuse... but strangly, there was no fuse there at all... oh well!
Old Dec 16, 2004
TeLLy's Avatar
Yes, it's an Acura EL
The story of your progress was very enlightening. Now if I can only get my hands on an 03 cluster, as well as the ability to change the milage on the odo, I'd be doing the same swap. rep up!
Old Dec 26, 2004
sp00n's Avatar
sp00n is an unknown quantity at this point
yeah as soon i put the cluster in my car it did the same thing.
so its real bright when you start the car. but when you turn on the headlights it dims.
so does it do that in the 03's?
Old Dec 27, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
got AAA sounds like you need to take it to an auto electrician. unless your battery was dead before you swapped the guages, then you may need a battery, or alternator.
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
BJB
Sep 14, 2015 11:16 PM
rayman009
Sep 12, 2015 08:30 PM
tomas6791
Sep 11, 2015 06:47 PM
