Micro Polishing??
Old Oct 29, 2004
HyaBoosta's Avatar
Micro Polishing??
I was reading an article on a d16 that was running 11.2's and they micro polished the crank. does anyone know what that process is and what it does as far as performance? I've never heard of doing that to a crank.
Old Oct 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
As far as i know they micro polish all cranks after they are ground. Or atleast all the machine shops ive been in do. Its like real fine sand paper that is sorta like a belt sander that they use on the crank as it spins.
Old Oct 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
had to search a while but found a picture..........
Old Oct 29, 2004
HyaBoosta's Avatar
i know what you mean about what the process is but i am more looking for what the benifit of having it done to the crank is? how would this better the performance of it? Maybe having to grind some of the crank then polish to balance the engine?
Old Oct 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by HyaBoosta
i know what you mean about what the process is but i am more looking for what the benifit of having it done to the crank is? how would this better the performance of it? Maybe having to gring some of the crank then polish to balance the engine?
well, when they grind the crank its literally GRINDING it with a grinding stone (more exzact then your bench grinder ) this leaves a fairly rough surface then the polishing does as it sounds, removes the imperfections from grinding and makes it real smothe, as for balancing this has basically nothing to do with balancing. When they balance a crank its either drilled out to remove weight or drilled out then a heavier weight is put back and welded in.
Old Oct 29, 2004
HyaBoosta's Avatar
Well i wasn't talking about taking an air grinder and going at it in my garage,Gotta give me more credit then that, Lol. but i still don;t get what that does for performance. It seems like a maintenence job.
Old Oct 29, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
Decreases friction, helps oil delivery across the entire bearing, increases bearing life. The harder you work your rods, the better your crank and bearings needs to be prepped.
Old Oct 29, 2004
HyaBoosta's Avatar
^^ good info.
Old Oct 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
Sorry didnt mean to make it sound like that, i was just being a little sarcastic. my appologies
Old Oct 29, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
The smoother it is, the less stress risers there are, and the higher the fatigue strength. The cyclic loading the crank undergoes is quite violent, so being able to increase the fatigue limit is advantageous.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
Ccoop87
Jul 9, 2015 03:26 PM
icebergslim
Apr 2, 2002 03:55 PM
