Funny noise coming from trans
Old Nov 14, 2004
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
I have an 02 DX with a manual trans. When i press the clutch in the sounds goes away but when i realease it it makes like a whining sound. WHen i put it in gear and take off if makes this ticking noise that gets faster with speed.When i shift to 2nd it slows back down and kinda goes away in 3rd 4th and 5th gears. What could this possibly be? The dealership had it for 8 hours friday and didnt even look at it. Its got 29,000 miles on it.any help would be appreciated
Old Nov 14, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
It's a Little early but I would flush the Trans fluid and see if that helps...
With 30k u should still be under warranty so I'd fuss with the Honda people if
that doesn't help.
Old Nov 14, 2004
I'm The Shit
its still under warranty but theyre *** holes to me cause id sued them b4 and won cause they wouldnt fix my fuel gauge after 7 tries. I was just seeing if there was a quick fix or not. Ive never had a manual trans b4 and dont know how to change the fluid out
Old Nov 14, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well jack up the front of the car, remove the passenger side wheel...
you should see a bolt on the side of the tranny by where the axel is, use a 3/8" ratchet to unbolt that... its a plug with a square drive deally... you will know what i mean..
you will need 2 quarts of honda mtf.. or something similar.. the manual says 10w30 works too.. but lacks the clensing agents found in the mtf
next locate the filler plug a 17mm box wrench should do the trick... it should be behind the tranny and farther up than teh drain plug
next get a tube and funnel, or tranny filler deals that screw directly into the bottle... and get a comfortable elevated position for the bottle... that way gravity can o its work... since its not 80w90 you dont have to sit there for an hour to let it go into teh hole...
they say that the fluid level should be level with the filler plug hole...
Old Nov 14, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Its probably the input shaft bearing. Mine was doing the same thing, they replaced it under warranty.
Old Nov 14, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
That does sound like the input shaft bearing. It seems a couple of people have had this exact failure. And, no, this should not happen so early.
Old Nov 14, 2004
Mine happened at 27,000.
Old Nov 14, 2004
I'm The Shit
what exactly is the input shaft bearing? I dont want to sound like an idiot tomorrow and the dealership
Old Nov 15, 2004
4jacks's Avatar
If that is the problem, and you are having trouble with one dealership, go to another dealership and tell them about the problem. They will still fix it under warranty.
Old Nov 15, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Would the input shaft bearing be responsible for a groaning noise between shifts? I can replicate it very audibly if I say, accelerate in 1st, then disengage the clutch and let the engine fall back to idle. During the decline in revs, I get a noticeable noise I never really had before. I'm at 38K, it's been doing it for a few thousand miles now.
Old Nov 15, 2004
Possibly, the input shaft bearing is the first bearing on the transmission right after the clutch.
Old Nov 15, 2004
VTEC01EX's Avatar
Of course... It started right around 36K. It's probably by design.
Old Nov 16, 2004
I'm The Shit
its something inside the trans banging around the dealership says. My car will be out for 2-3 weeks. Ill letyall know what they find out.
Old Nov 17, 2004
zdriver's Avatar
zdriver is an unknown quantity at this point
hondacare paid for my input shaft bearing, gearset, and clutch, thank god for warrantys
Old Nov 17, 2004
nindoo's Avatar
Why is my vagina bleeding?
mine makes a whiningf sound if i engage the clutch at 3000 RPM. Is that what your getting a whininng sound. I have no idea why my car is doing that.
pratik05
May 15, 2015 01:54 PM
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
