Rwd
Old Nov 25, 2004
flowerpowerlove's Avatar
just breathe...
flowerpowerlove is an unknown quantity at this point
Rwd
anyone have thoughts or ideas about going RWD? could it be done?
Old Nov 25, 2004
TrboEM2's Avatar
Member
TrboEM2 is an unknown quantity at this point
i will keep quiet for this one and leave the flaming to everyone else
Old Nov 25, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
yeah. import a C4 or XL4 ferio and convert over to full time AWD or try fit the wagon AWD on to yours.
Old Nov 25, 2004
C2i0v0i1C's Avatar
SuperMODrizd
get another car
Old Nov 25, 2004
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
anything could be done if you have the cash, but 4 the about you'd put into converting the car 2 rwd you'd prob be able to get a really nice rwd car.... Although it would be halarious to see a vic w/ a s2k engine, doing a burnout from the rear!
Old Nov 26, 2004
just breathe...
wow, some of u guys are hostile... just tryn to think out of the box
Old Nov 26, 2004
mugenman's Avatar
"mmmBAHHHH" - vtec y0
dude ive thought outside the box i even went as far as 2 see what needed 2 be done for a rwd s2k conversion search my posts its there and people can be straight up a$$holes about stuff like that
Old Nov 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if u got the money go ahead and try it, it will be amazing when its done, but i think ull be in for one heck of a ride to get to that point though
Old Nov 26, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
yup, its a shame people cant give their ideas and thoughts on this board with out getting verbaly abused, isnt that what this board is for?
i think it would be a great idea
Old Nov 26, 2004
nindoo's Avatar
Why is my vagina bleeding?
Take the differentials of a CRV modify them and try an use that I guess. I guess the new RL stuff would be expensive.
Old Nov 26, 2004
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
the rwd civic with s2k motor in the trunk has crossed my mind but I have never researched. Motor might be too big to fit or way too much money???
I saw an old tibouron with a normal engine up front and a Cesna engine in the trunk/hatch area running two seperate transmissions. So I think anything could be done, but I have no Idea on the cost$$$$??
Hey they did it with the focus and cavalier as well. Those are around 10g's I think.
Research and let us know. Know harm in that.
Later
Old Nov 26, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
for the most part like engine, tranny, and all that stuff would be easy to get but the fabrication is going to be a pain you would need new spots for mounts, cut and weld ****,then if you want to be a sav try and figure out weight disturbution because if you want RWD whats the point if its going to off balance you have to have the engine sit in just the right spot, i have put days of thought into swapping a s2k engine in my car, some day someone will do this and i hope its me but until i hit the lotto or become bill gates bitch ill just stick to the k20, or get an evo
Old Nov 26, 2004
Bmkarr's Avatar
yea its all mount relocation honda subframes are all the same so you could drop any engine into any honda and itll fit with the exeption of the nsx of course
Old Nov 27, 2004
pon55's Avatar
FLAT FLOOR PAN = big problem. How about rear engine and rear drive?
Old Nov 27, 2004
allmotor's Avatar
nor cal 7thgens
yeah that would be something if someone did that but i doubt anybody would be that dedicated time and money wise
Old Nov 27, 2004
Redline04's Avatar
That's what I was thinking, but is there room in the rear?
Old Nov 27, 2004
pon55's Avatar
Depends on how bad you want it! my-bad sorry
Old Nov 27, 2004
pon55's Avatar
You would have to use a transverse set up!Cooling on top,engine low,could probably fit a K20.
Old Nov 27, 2004
pbfoot's Avatar
youre not really thinking outside the box because this has been talked about on the boards since the beginning. so no, its not an original idea.
and to answer, no...youre better off just getting a different car. unless you want to spend WAAAAAAAAAAAAAY more than the car is worth doing this mod. for what? show points? even if you succeed, the car will never handle like it was designed to, who knows if safety standards will be compromised, crash ratings etc., its just not worth it, it probably wont be street legal anyway.
if you really want a civic, youre better off just importing the AWD from thailand or whatever like someone else said. save yourself the hassle.
Old Nov 27, 2004
Danka02's Avatar
SICCMADE
but that takes the fun out of trying something new that nobody has done yet. If you have the cash and time do it like i said just make sure you figure out weight placement
so its not off balance and the car handles well.
Old Nov 28, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
There is a D1 integra with a b18 and the trans off of a crv converted to rwd. I was thinking of going hardcore frankinstein but said it would be two expensive. either way check it K24, Rsx type R head, Crv trans, and convert the whole car to AWD. then throw a turbo on it just for sh*ts and giggles. that would be a sleeper STI killer for sure.
Old Nov 28, 2004
lkm's Avatar
lkm
Super Member
you people still aren't listening. Importing a C4 or X4 civic ferio from japan then coverting it over to full time awd or rwd is the best and easiest way to do it.
Old Nov 29, 2004
LiKEaFeRiO's Avatar
Listen to the guy!!!
This is technically the easiest way to do it.
And it would probably be cheaper than custom fabricating a new floor plan for RWD.
Or you can study this model to figure out how they got the rear drivetrain in there.
The AWD model on the Civic Ferio (sedan) models are equipped with a semi-AWD system, just like the AWD Mazda 6 thats due soon.
The Civic is mainly FWD and only gets power to the rear when it's needed but the drivetrain is there...only thing you need to do is make it fulltime AWD or somehow change it to RWD.
I believe it can be done without too much money.
Old Nov 29, 2004
just breathe...
dang, take a chill pill. duh, i realize that i am not the first one, just throwing it out there since this seems to be the only website with info for our cars and hadnt seen a thread for it.
relax...
Pinoypryd
Aug 1, 2004 12:55 AM
guamcivic2k1
Apr 6, 2004 09:34 AM
trev0006
Mar 27, 2004 07:08 PM
kenji4861
Dec 25, 2002 12:04 PM
