FWD VS RWD - RWD IS BETTER?
Rep Power: 0 FWD VS RWD - RWD IS BETTER?
This is my conversation with a friend.
K E N J I 4 8 61: I personally don't know why RWD has advantage
Takeru *: im not gonna race or anything..
Takeru *: when u accelerate
Takeru *: the weight goes to the rear wheels
Takeru *: so RWD gets more traction
K E N J I 4 8 61: compared to FWD?
Takeru *: yea
K E N J I 4 8 61: then why's all our cars not RWD?
Takeru *: FWD is easier to handle..
Takeru *: and easier to build
Takeru *: cause u don need a drive shaft
Is this true?
Takeru *: yea
Is this true?
Rep Power: 0 Let me get this cleared up
RWD - accelerates faster
FWD - better handling
AWD - both?
So... a AWD 160hp car would accelerate faster than a FWD 160hp car?
AWD - both?
O RLY
Rep Power: 375 no.... RWD cars will handle better as well. Also better for accelerating, and better for launching. Though AWD is king of the launch, but more power is lost from the crank to the wheels.
and yes, RWD needs a driveshaft, as where FWD uses a transaxle.
Quote
[hr]Originally posted by: kenji4861
So... a AWD 160hp car would accelerate faster than a FWD 160hp car?[hr]
O RLY
Quote
cars that are AWD don't necessarily accelerate faster... they just launch better.
Retired suspension supermod.
Rep Power: 387 But the AWD will probably have the best handling out of all of them. FWD cars save some power by not having to send the power to the rear wheels (besides cars that have the engine in the rear). The are easier to build, but both RWD and AWD will own off the line. Just think of it this way. You have a cart with wheels that has a 40 inch TV on top. Will it be easier to push or pull that cart? It is definitely more easier to push that cart. Now if you could push AND pull that cart, you will get places a little quicker.
Rep Power: 0 RWD cars CAN handle better than FWD but is harder to drive.
The everyday average driver will handle a car better on a FWD than a RWD. Your directional
wheels are not your accerlating wheels for a RWD car so in fact you actually have MORE control if
you know what your doing, but you'll need more torque to correct yourself out of slippery conditions.
Rep Power: 0 fwd sucks, or does it? http://home.insightbb.com/~hlh0501/h..._fwd_sucks.mpg
Quote
[hr]Originally posted by: robbclark1
But the AWD will probably have the best handling out of all of them.[hr]
O RLY
Quote
[hr]Originally posted by: ZeroFighter
fwd sucks, or does it? http://home.insightbb.com/~hlh0501/h..._fwd_sucks.mpg[hr]
O RLY
Rep Power: 375 Didn't say it wasn't possible. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] but you'd be hard pressed to do it.
on top of that, if you are talking equal mods, ie, same suspension work on a RWD and FWD, the RWD will still own on the launch.
Rep Power: 0 Heh, for gus it was a matter of putting a block of wood under the one side of the swaybar, moving the battery to the passenger's side, and getting an alignment and some practice in.
Once he geared it down and put it on slicks, it was down to 1.8-1.7 range. Very impressive for a stock suspensioned FWD vehicle, and unpossibly crazy for a minivan!
Rep Power: 0 RWD is better for launching, and allows you to launch at a higher RPM. FWD does not handle better than RWD Cars, they are "easier" to handle. On the other hand, RWD handles better than FWD cars, albeit harder to control and requires more skill. As you get used to it, the back coming out becomes quite predictable and allows you to control the fish tailing.
Do FWD cars transfer the weight to the Rear of the car under acceleration? While RWD transfer the weight to the Front?
I drove an 1995 M3 before this civic, driving the civic is a piece of cake. But i must say that RWD is better handling around corners. AWD is good for accel but cheap at the topend. Anyways, i guess the fact it was an M3 might have somethin to do with it [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Rep Power: 387 I don't miss it at all but maybe it is because I had a 4 cyl mustang which had less HP than my civic. I hated taking turns in wet weather and sliding because there is no weight in the back. I think my civic handles better.
O RLY
Quote
[hr]Originally posted by: Neonmike
Gus Mahon used to get 1.9s with an open diff on all season tires in a dodge minivan. It's all about proper suspension tuning.[hr]
A 1.9 60 ft requires around 0.9-1.0g of avg. acceleration (depending on how much time is elapsed during the roll out - call it 1 to 2 tenths). You'd be hard pressed to generate 1 g under braking with your typical all-season tires, let alone sustain it accelerating in a FWD vehicle where all the weight is being transferred off the drive wheels. A 2.2 second 60 ft requires in the vicinity of 0.7 g which is really pushing it even on sticky tires for a FWD vehicle. Most FWD cars on street tires are hard pressed to generate more than 0.55-0.6 g peak acceleration before tire slip - hence the difficulty for most drivers to do better than a 2.25-2.3 60 ft on streets.
Quote
[hr]Originally posted by: PESTLNC
After coming from a RWD to my FWD Civic...dear God do I miss RWD.[hr]
1 Post
Rep Power: 0 These are all generalizations, there are exceptions to these rules in any case...
FWD is better when cost, size, weight, and efficiency matter, for mom and pop it is the best all around choice. It also provides better traction in mid to low horsepower applications by biasing the weight of the vehicle forward thus it a better choice in snowy climates as well.
RWD is better when weight, efficiency, steering performance and dry track handling are important. It is ideal to have a mid engine rear driver, though RWD is far from space efficient.
AWD is the better choice when traction and controll are critical and weight and performance are not key. thus it is the best choice in snowy climates, for dirt tracks, rally racing etc... The cars are generally heavier, slower, smaller per unit weight, less efficient, and more expensive than their counter parts.
fuledya
02-22-2003 08:57 PM
