Installing Venom400
Old Nov 22, 2004
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Installing Venom400
Alright Before yall Flame. I Checked, then didn't find it Then Got Angry and I decided to post a topic..... Give me some Idea's On where Some of u Mounted Ur Venom400. And I have another ? Where is my Ecu located, And what exactly Do I have to do in order to Install. Thanks
Old Nov 22, 2004
freeturkeys's Avatar
freeturkeys is an unknown quantity at this point
ecu is under your cupholder. sort of. just pretend like your changing your radio for the first time and you'll see it in there
Old Nov 22, 2004
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Just wondering if you had seen these reviews before. Check out the 3rd one down: http://www.7thgencivic.com/parts_rev.../cat/19/page/1
Old Nov 22, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
I've got the venom and it DOES work, its not the same as just flooring it all time. Anyways, I've done several time tests with it on and off, and its definitly quicker with it on. Its only a 4 wire hookup all under the hood, 2 on the battery (pos/neg) and 2 by the throttle body (tps and map) I mounted mine on the firewall right behind my intake. Thanks and good luck, just follow the instructions that come with it because it tells you the correct color wires to look for by the throttle body. later....
Old Nov 22, 2004
IDQcivic's Avatar
oh and i more thing, the ECU is NOT under the cupholder, its behind the glove box..... but you dont need to find it to install the venom....
Old Nov 23, 2004
Marcus's Avatar
thanks Man
Old Jun 26, 2005
hondero23's Avatar
hondero23 is an unknown quantity at this point
Hol Asoy De Puerto Rico Necesito Saver Si Me Pueden Ayudar Estoy Buscando El Diagrama Para Montar Una Venom 400 De Un Civic 01 Dx [/b]
Old Jun 26, 2005
throw it in the trash
Old Jun 26, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
something like this-
" I am looking for the Diagram Me To mount a Venom 400 Of a Civic Dx"
Old Oct 26, 2005
CivicLX_Black's Avatar
CivicLX_Black should not be trustedCivicLX_Black should not be trusted
Which wire color does the orange and green splice into???
Old Oct 27, 2005
Michalo187's Avatar
Abortion Survivor
When i had it it felt like it helped quite a bit. I had mine inside the car so i could turn it on and off. I even raced a car and lost by a tiny bit i turned the venom on and beat him by 2 cars. I think this does really work and i don't really believe in any other products for the civic
Old Oct 27, 2005
joescivic02's Avatar
Abercrombie and Fitch
mount it in the glove box
Old Oct 27, 2005
If the venom 400 is not for your car and belong to another. The performance will not be as great and you might want to call up Venom to reporgram it for 59.95 . But be sure YOU ASK THEM FOR THE SIX DIGIT NUMBER IT SHOULD HAVE (***-***). ALSO BE SURE TO ASK THEM FIRST DON'T GIVE THEM YOUR NUMBER JUST INCASE THEY WANT TO LIE TO YOU.
Old Oct 27, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
what part number is the one that will work on are cars
Old Oct 27, 2005
Michalo187's Avatar
Abortion Survivor
v21-141 if i remember from when i had it
Old Oct 28, 2005
I don't know the part number but the onw i have was off my 1999 Mercury Cougar and i'm sending it for reprogramming on my 2005 Civic LX.
I don't know who posted it but they said that i work really good for the non-VTEC civics. The EX and (LX, DX,VP) civics have differnt 6 Digits also 01-03 and 04-05. For the 2005 model the 2004 parts will work. Almost every part on a 2004 will work on a 2005. I konw, all the parts i've bought are for 04.
Old Oct 28, 2005
If anyone is wondering how the venom works i'll just say it.
All it does to manuel car is take-in more gas like bigger fuel injectors and speed up the coil to spark more. It make a big difference. But on Automatics it does that plus makes sure you hit red line. Very useful for the people who use ATUOMATICS. BUT............................................... .................................................. ..CAUTION: WHAT I'M ABOUT TO TELL YOU WILL HAPPEN AND YOU WILL BE PISSED. THIS ONLY AFFECT AUTOMATICS. IF YOU ARE ONE OF THOSE PEOPLE WHO TRIES TO TREAT YOU CAR LIKE A MANUEL AND YOU DON'T HAVE A SPORT SHIFT ON YOU CAR YOU WILL BREAK A BAND ON YOUR TRANSMISSION.
THE PROBLEM IS THAT WHEN YOU MAKE YOU TREAT YOU AUTOMATICS TRANSMISSION LIKE A MANUEL AND THE VENOM IS ON. YOU CAR WILL DELAY THE SHIFT PAST RED LINE AND INTO THE DANGER ZONE. SO MAKE SURE IF YOU DO THAT CRAP YOU SHIFT THE AUTOMATIC TRANSMISSION EARLIER ABOUT 500 TO 750 RPM.
PRIVATE MESSAGE ME FOR MORE INFO.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
