Air/Fuel Gauge and O2 Sensors
Old Apr 18, 2005
Kubias's Avatar
Member
Kubias is an unknown quantity at this point
http://hp.autometer.com/instructions...nstruction.pdf
Will this work with an autometer a/f gauge? Or will it still just bounce around??
Old Apr 18, 2005
Octane Joe's Avatar
UM... your air/fuel DOES bounce around, that is what it does.... if it doesnt move around, you hooked it up wrong or your car is f@#cked...
Old Apr 18, 2005
Kubias's Avatar
Member
When i hook it up to the stock sensor it bounces around. If i were to hook this up will it stop bouncing and actually read?
Old Apr 18, 2005
Octane Joe's Avatar
Bouncing is what it is SUPOSED TO DO!!!! the air fuel mix does not stay constant, if it did, your car would not run properly... an air/fuel ratio moves around sporadicly the only time it is farily constant is when you are at WOT. as for intalation, here is a link for the DIY, if you do more projects I highly suggest looking in this section of the forum, it has a lot of good info... A/F DIY
Old Apr 18, 2005
Kubias's Avatar
Member
OKay, One more question. I've seen that hooking it up to the sensor can ruin the sensor. Is it any better/worse to hook it up at the ECU??
Old Apr 18, 2005
ajhdragon's Avatar
7thgens official a$$hole
mine is on my main o2 sensor. the ecu dosen't read properly.
Old Apr 18, 2005
Kubias's Avatar
Member
How long has yours been on there? Have you had to replace the sensor at all?
Old Apr 18, 2005
ajhdragon's Avatar
since august and no.
Old Apr 18, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
is there any reason to have this gauge unless u have a turbo?
Old Apr 18, 2005
ajhdragon's Avatar
tuning i have a hybrid setup im runing a dx ecu on an ex d17a2, and i tuned the car with the VAFCII, and my NO2 is coming in
Old Apr 18, 2005
Kubias's Avatar
Member
what about running nitrous?
Old Apr 18, 2005
booba5185's Avatar
ah, i have a tach in my auto, everyone says it's useless, but i watch it for gas mileage, would there be any type of benefit in that way, or would it just be completely retarded to have it
Old Apr 18, 2005
ajhdragon's Avatar
you have to tune it right befroe you can run NO2 or else you can have detination and stuff which = not good. so it has to be a little richer in wot to prevent it.
Old Apr 18, 2005
ajhdragon's Avatar
did you put the tach in your auto? cause if you did i find that kinda retarted. and if you plan in tuning your car get an a/f guage, it won't hurt anything.
Old Apr 18, 2005
booba5185's Avatar
yes, i did put a tach, but thats because i have a dx with no tach and it's not a huge 5 14", it's like 2 3/4 at most i dont remember the exact size but, it's small, the only reason i got it was so i could pay attention to rpms for gas mileage, not to try and guess where it'll shift for itself
Old Apr 18, 2005
ajhdragon's Avatar
yeah i put a tach in my dx as well but i have a 5-speed and i have a volts guage that is basically just a pretty light to fill the hole in the guage pod, but will be replaced with the boost guage.
Old Apr 18, 2005
tdiddy's Avatar
tdiddy is an unknown quantity at this point
how did you guys run the wiring to the engine bay.
Old Apr 18, 2005
ajhdragon's Avatar
i ran it behind the radio and glove box through the little ubber gasket thing on the fire wall i nthe engine bay, then up to the o2 sensor. yo uonly need to run 1 wire through the bay. the power wire you can run to an open slot in your fuse box, along with teh wire that turns the light for it on, which means the light for the guage will always be on when the car is on. and ground it to any ground.
Old Apr 18, 2005
tdiddy's Avatar
Thanks
Old Apr 19, 2005
Octane Joe's Avatar
For lighting, you can also go to the back of your HU if you have an aftermarket one! that is what i did, so easy!
Old Apr 19, 2005
booba5185's Avatar
no no no bad that makes ur sound quality go way down, hook it up to the cig lighter, just as easy
Old Apr 19, 2005
Octane Joe's Avatar
2 things wrong w/ this post, first, take the lights off the dimmer line off the HU wire harness, aka off stock harness, will NOT effect your sound quality... #2 Cig lighter is a constant feed, your lights will be on all the time, looks very stupid to have your back lighting of your gauges on when the rest of your dash is not illuminated
Old Apr 19, 2005
booba5185's Avatar
oh, i thought u mean the ign power like someone who will remain names did with their tach, my bad
h4ldol
Apr 24, 2017 08:16 PM
srtlat
Sep 17, 2015 11:02 PM
Juanb24
Sep 15, 2015 12:39 AM
Dave Brabant
Sep 10, 2015 06:48 PM
JetsterDajet
Aug 16, 2015 01:56 PM
