DIY: First time changing brake pads
Old Mar 6, 2005
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
I know DIY for changing brake pads have already been done, I actually looked at quite a few before trying it out on my own. Sorry but I forget the names of the 7thgenners who put up the other DIYs, I know Boilermaker's was the last one I read besides the "brake and rotor DIY" in the DIY section.
Anyways, I figured I would try changing my brake pads for the first time despite people telling me it was too hard or that brakes are too dangerous to mess with. So after doing my research on the 7thgen website, I got down to business.
1) First, I took a gander at my scuffed up rims and pondered whether I should sell them and get some new wheels. Then I jacked up the car and took off the wheel.
2) Second, I laid out the tools I was going to use (from left to right):
- Vise-grip (for pushing the piston in)
- 12mm socket wrench
- adjustable wrench (used it to hold a washer while taking off a bolt)
3) Turn the wheel to the opposite side you are working on for better access to the bolt you have to remove. I sprayed the bolt circled in blue with a little Liquid Wrench (don't know if it was really necessary because it came off easy). Held the squarish washer with an adjustable wrench because it was turning along with the bolt. Notice my handy little flashlight (optional).
4) After taking off that one lower bolt, you can swiftly pivot the caliper up and out of the way. Now you can see the worn pads on the inside. Wiggle off the outer pad (the one nearer to you) and take off the shim. Also remove the inner pad (the one that has a little handle on the bottom) as well as the retainer clips (don't know if this is extremely necessary.
5) After getting everything off, time to do some cleaning and greasing:
- use brake cleaner to clean off the rotor and the caliper
- grease the part of the retainer clips that will mount to the caliper
- grease both sides of the shim
- grease the back of the brake pad
I'm getting new rotors sometime soon, so I didnt worry much about rotor resurfacing or machining. Just check it for cracks and rust.
6) Wow, it's about damn time I change out my brakes. Been riding on these for 4 years and nearly at the point of metal on metal action.
7) Push in the piston with a vise-grip or c-clamp and make sure the brake fluid doesnt overflow. The piston will stay in place as you push it in.
8) Pop on the new pads and make sure no grease is on the rotor. Screw the bolt back on and you're nearly good to go. After that, bleed the brakes and go out for some test braking.
** I'm not saying this is the official or perfect way to do it but it worked for me. All in all about 1 hr. **
Old Mar 6, 2005
armieo's Avatar
< My future wife.
You painted your shocks green?
Ricer...
just kidding
Old Mar 6, 2005
TemjinX2's Avatar
nice DIY. i gave you a rep point.
Old Mar 6, 2005
JCiv03's Avatar
Very nice and detailed DIY. This is great for noobs like me. Btw, nice Teins!
Old Mar 6, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
You dont have to bleed the brakes as long as the master cylinder reservoir stays full which it should
Old Mar 6, 2005
^^^just pump the brakes a bit after you put everything on the so the piston is in contact with the pads
Old Mar 6, 2005
dubz01si's Avatar
dubz01si is an unknown quantity at this point
hawk pad's right on man!! i have a pair of HP + club pads
Old Mar 6, 2005
izmaxx's Avatar
Yeah, I didn't have a clue about what brand of pads to get so I went off the feedback I heard on the forums and my buddy SilverSleeper. Hawk pads are awesome.
Old Mar 6, 2005
silverem2's Avatar
yea, those factory green tein coilovers are truly rice.....
Old Mar 6, 2005
izmaxx's Avatar
funk y'all, look what you started armieo!
Old Mar 8, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Pushing the fluid back to the master cylinder is bad especially for those who have ABS. You should use a vise grip plier and clamp down the brake line to prevent deposits from pushing back to the master cylinder.
Old Mar 8, 2005
armieo's Avatar
< My future wife.
Rofl tell me what your license plate says, ricer. Testament to your true single-grain nature.
Old Mar 8, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
HAHAHA
Old Mar 8, 2005
scatman's Avatar
Still in the game...
nice write up
Old Mar 8, 2005
izmaxx's Avatar
Jackmunch, what happened to riceteam?
Old Mar 8, 2005
zachgeyer's Avatar
nice diy
Old Mar 8, 2005
armieo's Avatar
< My future wife.
Riceteam is still holding on strong. I was str8 KL0wNing.
I'm the bigger ricer for not having a drop or an exhaust. Just a rusty old muffler tip from autozone. Yaheard?
Old Mar 8, 2005
skipbarber's Avatar
wow, you need some fresh brake fluid daddio. I don't know if it makes a difference, but when i change my pads, i take the caliper off the rotor competely, you left the carrier on there. Like I said, dunno if it makes a difference.
Old Mar 11, 2005
izmaxx's Avatar
Yeah I noticed that some people take the caliper off completely but I took the lazier approach. I bled the brakes but didnt totally replace the fluid. Trying to find some of this super blue stuff everybody is talking about.
Old Mar 13, 2005
silverem2's Avatar
lol who gave me neg rep in here? lol as if you cant feel the sarcasim in my first post after reading right from the top.
Old Mar 15, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
very good and detailed DIY!
+1 rep
Old Mar 15, 2005
tfnaaf's Avatar
BLDNPSI Mod
^^^^^ Is mostly correct about the pushing the fluid BACK in to the master cyl/ ABS. But the proper way to compress the caliper piston is to open the bleeder then compress the piston. this way any particles exit the caliper instead of being pushed back up into the master cyl or even worse the ABS!!
Old Apr 14, 2005
cubanmike26's Avatar
Nice job with the DIY man! Definately handy...
Old Apr 14, 2005
orion_squall's Avatar
great
Always thumbs up for people who spend their time to make DIYs!
mattdoc
Mar 14, 2017 12:10 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
edgenet
Apr 28, 2015 07:49 PM
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
