interior painting...
Old Mar 28, 2002
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
i was wondering what kind of paint can i use on my dash? i know u can't just use any paint on the soft trim because over time it will crack, so what do you peeps recommend? i want my interior similar to platnumbomb's ride, but with more trim painted. please help. i searched and did not find n e thing. thanks.
Old Mar 28, 2002
Narflar's Avatar
Narflar is an unknown quantity at this point
Look in the DIY page, at the top.
DIY Painting Trim Pieces
Old Mar 28, 2002
VNlilMAN's Avatar
The Standard One
they're a couple companies...
g2(look under parts section), foliatec?(something like that), and dupli-paint?(something with dupli in it). these are all made for dashes. they claim to dye the dash rather then to just putting paint on it.
Old Mar 28, 2002
Confinement's Avatar
Confinement is an unknown quantity at this point
check out my ride i did it and i used plasticoat paint and it has a glossy finish to it instead of a dull look that you will get with regular paint.
Old Mar 28, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
<< check out my ride i did it and i used plasticoat paint and it has a glossy finish to it instead of a dull look that you will get with regular paint. >>
I couldn't find your ride in member rides...If u still need to look at some painting examples...check mine below...or Stylin2k1...or look around some more...
-g0rd0
Old Mar 29, 2002
VNlilMAN's Avatar
The Standard One
he wants to know what to paint the actual dash with, not just the dash trim.
Old Mar 29, 2002
dood...I used folliatec on my dash...Check out the bottom pic on my link...the first one is the "before"...the bottom is the "after"....
I know what he asked!
-g0rd0
Old Mar 29, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
On my old 99 ex I used high temp engine pant. Washed the peices with soap and water, rinsed with rubbing alcohol. Then I put 4 coats of the spray paint on, let dry in between. Then I did 3 coats of clear coat, and let dry in between. Worked perfect and lasted on my car for 3 years. No cracking, fading or peeling.
Old Mar 29, 2002
VNlilMAN's Avatar
The Standard One
<< I know what he asked!
-g0rd0
i was talking about the other people replying to this post.
Old Mar 29, 2002
VNlilMAN's Avatar
The Standard One
i just saw your car, it looks pretty nice. are you planning on finishing the rest of the dash? and did you take it off(the whole dash) or just tape around it when you painted it?
SammySC
121
Apr 7, 2017 07:43 PM
cferry7
Oct 18, 2015 06:32 PM
dhuff
Sep 28, 2015 08:35 PM
speedlever
Sep 24, 2015 07:18 PM
Dsmak
Sep 22, 2015 05:16 PM
