LX to EX exhaust conversion, need help!
Old Feb 28, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ok so i did my lx to ex exhaust conversion, but instead ofgetting the ex sway bar i just took mine off, and frankly theres no difference in handling as far as i can tell. but is this bad for teh car? oh also, i need to get the EX o2 sensors since the LX ones cant reach all the way to the EX catalytic converter, will this still work ok with my LX ECU? and finally, do i need the o2 sensors? i heard that on newer cars tehy actually regulate the air:fuel ratio?
edit:
oh and if i need any of these parts, where can i get them for cheap?
Old Feb 28, 2004
2003hondacivic's Avatar
2003hondacivic should not be trusted2003hondacivic should not be trusted2003hondacivic should not be trusted
hey man i am tring to do the same thing where do you fine the parts from
and ehat all did you have to git
Old Feb 28, 2004
CiViCLiZeD714's Avatar
is this even worth the hassle? can't you just get the kamikaze headers with a high flow cat and make more power then this conversion?
Old Feb 28, 2004
ok well i already have my exhaust on there so im not doing that, plz dont start flaming, just stick to original topic. oh and 2003hondacivic, all you have to do is buy the EX header/catback exhaust/downpipe, and then take off the LX front sway bar, and stick everything on.
Old Feb 28, 2004
ma bad...i'm not trying to flame you...i was just curious since i have been interested in this topic forever
Old Feb 28, 2004
Merciless's Avatar
Merciless is an unknown quantity at this point
Does it add more horse or something? If so cool but I would think you would be better off doing a custom set up I would also guess it would be cheaper than stock honda parts...I am very confused why you would take off stock honda parts and put more stock parts on...it can't be that much of a difference or is it?
Old Feb 28, 2004
Hypnotik's Avatar
Hypnotik is an unknown quantity at this point
u dont necessarily hafta convert to stock EX parts! the main advantage of an EX exhaust swap is being able to use the many different catback systems available for EX only. so just get a highflow EX header/downpipe (kamikaze or HP racing) and then bolt up a nice exhaust. it wont give you much more power than just the LX kamikaze headers, but it is nice if you want a specific exhaust that's EX only (like the RS*R that i want...)
Old Feb 29, 2004
Merciless's Avatar
Also I dont see why you want to mod a LX...non-vtec not ever going to be fast or anything civic you better jump onto a K20 swap or even A d17a VTEC swap. Not flamin you just trying to let you see the light that you are wasting your money.
Old Feb 29, 2004
Project2k2's Avatar
Merciless dude, do u have any faukin idea of what your talking about?!?!?!? Stop posting meaningless **** like your drunk...no one cares.
Where did you get that modding an LX is pointless. In most cases a SOHC VTEC doesn't make but a hair of a difference. so 12 hp stock sure does sound like a good reason to swap my engine right?!?!?!?!?
Old Feb 29, 2004
Merciless's Avatar
Well let me make this more clear for you. SOHC motor for a Honda=****. That better?
It takes too much money to make any power that is worth talking about, It can be done but why? If he wants to make power he needs a K20 in his car or a K24. LX motor=**** even the D17A isnt that great as I said before a SOHC Honda motor isn't worth modding.
This is the main reason I am going from a D16Y5 to a B18B Turbo set up why you ask... well lets see more liters which means more TQ also they make more parts for a B18B than they do a D16 hmmm just saying in the long run he will save money by getting something that tuners make parts for other than the ANEMIC SOHC motors.
Old Feb 29, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
meh, you are just making yourself [merciless] look like an ***. You're not cool coming on here and telling us our motors are shitty.
Old Feb 29, 2004
Merciless's Avatar
Well lets see I am not making myself look like an *** you guys are maikng yourselves look like ricers trying to mod these worthless motors. You are the people that give people that mod imports a bad name trying to make this LX and EX motors fast...
ok I am from www.azsr.com/forum
these guys dont mess around with speed. If you aren't running at least a 11 you aren't fast but hey if you want to waste your money and run 13s with 5gs put into your motor go right ahead. All I know is most people would rather run fast times for less money. Which means you need Displacement for TQ and HP so upgrading to a K20 would be the best way to make power you can only go so far with these D17s....
Old Feb 29, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
OK so your saying spend over 10g's and do a k20 swap? Why would you do that when you can get a Sf turbo and tune the engine the way you want it. Its cheaper than the k20 swap and can even keep up with a rsx. Also if you boost with the ex you have to worry about boost spikes, when a lx dx you dont have to worry about it, since the vehicle has no vtec.
ricergribbs I would just add more wire to your sensors that you have now to make them longer, or look into a sim. Reason why I say that is because your going to be spending over 150 per sensor from honda. Just get some heat srink, wire, and a soldering iron, and a pair of wire cutters and have at it.
Jeff
Old Feb 29, 2004
Merciless's Avatar
So your saying do a sf turbo to run with a stock RSX....wow boy would you be fast.
If you swap the K20 you could trubo that and be running with SS's and Cobras but hey what ever floats your boat./
Old Feb 29, 2004
opto_isolator's Avatar
Jeff
Or instead of wasting your time listening to newbies - you can go here:
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
And they them for about $36 a piece. Of course those are for the 2001 EX, but its pretty much the same thing. Of course I'd probably just try the soldering thing first myself (since I am a cheapskate and all). Another thing you might have to take into account is that the locations for the wiring harness plugs in the LX are different than the EX, which means that even if you DO get the EX O2 sensors, the wires may still not be long enough.....Just some food for thought...
Old Feb 29, 2004
Jeff's Avatar
Lets get one thing straight, Im not a noob. If you look at my member date I have been around since the opening 2k1civic. I have done many different projects on 2k1 civic and integras, from guage cluster swaps to clutchs to trannys. Yes it would be nice to do a k20 swap but most of us on these boards do much more talking than swapping because of the price involved. Im only here to provide my knowledge about the car and from what I have seen on 2k1 over the years.
Jeff
Old Feb 29, 2004
Project2k2's Avatar
So eve if one of us were to have a set up like Catalyst, we will still have a "**** sohc"? He's running anywhere from 350-400 at the wheels. What's **** about that? Do your research before coming on here and saying our cars can't be fast.
Old Feb 29, 2004
ummm.. actually catalyst is running about 300whp at 11psi
Old Feb 29, 2004
Merciless's Avatar
Yeah he is running 300hp but how much more is he goning to be able to squeeze out of that motor before it hits its limits and isn't very daily driveable. You can make anything fast BUT you can save money and get more power out of different motors. Yeah there are those mean SOHC motors out there but very few...why? Becuase they arent worth modding compared to a K20 or K24 or and DOHC motor that Honda makes. There is a reason these other motors are popular...
Tell me how much money has gone into this 300hp car. Maybe he is one of those few people that can make this power for cheap.
Also I dont see many Civics with LX motors running anywhere near a "fast" number. 13s are not fast.
Old Feb 29, 2004
Jeff
I know - I just like being an @ss sometimes...
Old Feb 29, 2004
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
I have done the conversio you are referring to. ebay header, megan cat, megan catback exhaust. I am currently driving around with no front sway bar. the handling is fine, i have new sways which i will install later. i extended my wires and the car seems to be running fine, although i have the CEL on. Do some research here, there are lots of threads about the issues pertaining to this swap.
Old Feb 29, 2004
yeah, i rednecked up the o2 sensor before the catalytic converter, i just used some wire cutters to cut both of them, and then attached the one that is supposed to go after the catalytic converter to the wiring that is supposed to go before it. now im wondering if this will actually work? are the o2 sensors the same?
Old Feb 29, 2004
CoupeStylz's Avatar
Si(R) killer # 1
They have different connections, and perform different functions. From what I've heard, the first 02 sensor reads is for adjusting air/fuel mixture, and the second one checks the cat.
Old Feb 29, 2004
Project2k2's Avatar
Dude, what kind of car do you drive? If's it's not a 7thgen then stop bashing and go the **** away. Seriously dude, if you wanna say our cars aren't worth modding then have some respect for those who do think so. 300 whp is faukin amazing for our cars. To do a swap is mad expensive, and obviously most of us here can't afford much more then the car we are driving. If it hurts you that bad, that we are modifying out cars, then stop posting. A
And yes, 13's are very fast for our cars. It would be dumb to compete against a WS6 or any other V8, but the fact that someone can say they have a fast SOHC, it's quite respectable.
Old Feb 29, 2004
i second that ^^
Old Feb 29, 2004
coupestylz, i know they do different things, but are they the same setup? like is one sensor the same as the other? or do they have different designs? other then the connectors, does the actualy sensor differ?
Old Feb 29, 2004
Jeff's Avatar
Project2k2 hit that one right on the money.
Old Feb 29, 2004
Project2k2's Avatar
Hey guys, sprry to ruin your post. back to the actual exhaust topic.
I currently am running a full ex catback off of my dx.
I have Kamikaze header, Tanabe Extension Pipe, and APEX-i n-1 exhaust. the tanabe extension pipe can be found at nopionline.com or optauto.com for around 120 bucks or so.
Old Mar 1, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Just buy an EX header and exhaust...
Old Mar 1, 2004
BIG's Avatar
BIG
^^that is the easy part, the hard part is what to extend with o2 sensor wires with?
