how deliver more fuel to engine?
Old Feb 24, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
whats the easiest way to get more fuel to the engine? is it enough to just get larger injectors and get a greddy emanage and program it to deliver more fuel?
edit:
im thinking about supercharging my car and going about 7-8lbs of boost. and yes i know theres no supercharger out for our cars, but i want to see if its feasible to piece one together.
Old Feb 24, 2004
Shakana's Avatar
Shakana is an unknown quantity at this point
VTEC!... lol j/k...
Old Feb 24, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
still gotta deal with the tiny *** throttle body...
too much fuel isnt good... you also have to have it so you get more air as well..
Old Feb 24, 2004
yeah i know the air thing, i want to see if i can put together a FI kit without having to get the sf fuel kit, i want to run 8 lbs of boost, so im seeing if this will be able to provide enough fuel.
Old Feb 25, 2004
player's Avatar
First step would be to get injectors, and then getting a controller that will controll the Ecu to get more fuel. The problem is that u will only increase the amount of fuel upto a limit as our damn throttels are so small that not enough air would be sucked. the ecu controller will not allow the injectors to spray any more fuel because tha air ratio is too small. so the best way would be to turbo charge, supercharge, or hardcore fabrication of throttel.
Now if u know what ur doing, u can fadricate your own supercharder. but it will take some time patients and alot of knowledge
Old Feb 25, 2004
Goku's Avatar
Goku is an unknown quantity at this point
dude what is wrong with you go with a turbo there are alot better and you will nlove them alot more trust me even if it is an auto turbos are the way to go
Old Feb 25, 2004
opto_isolator's Avatar
Dude, don't you ever search before you post? I've seen like 10 posts from you asking the same damn questions over and over - SEARCH! You'll find what you're looking for.....
Old Feb 25, 2004
yeah, except ppl never seem to actually answer my question, and i have searched. everyone just says "go with the sf kit", they never answer anyones question about other ways to do it.
Old Feb 25, 2004
BS - I've written plenty of posts about fuel, including running my own return line this past weekend. Take the time and read, I guarentee you'll find what you are looking for.....
Old Feb 25, 2004
well first off youve never responded to any of my posts, and second im trying to find out if its ok to not redo the entire fuel system and just change the fuel injectors, and third sorry but i never saw any posts by you about fuel other then converting to a return style fuel system, maybe ive just been searching for wrong things.
Old Feb 25, 2004
tfnaaf's Avatar
BLDNPSI Mod
shrug... not sure why this would be the first step?
opto_isolator has these 2 following links on his fuel system VERY nice work! And if you are boosting turbo/supercharger the throttle bore would be the LEAST of my concerns. I would focus on the exhuast being the intake will be under boost opening the exhaust more will benifit much more then a larger throttle body. But thats just my opinion i could be WAY wrong.
http://www.7thgencivic.com/forums/sh...hreadid=140975
http://www.7thgencivic.com/forums/sh...32#post1658432
CarStuff
Dec 6, 2020 12:52 PM
superstanko
Apr 28, 2015 04:38 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
TaiChi
Dec 17, 2001 09:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
