Compression test
Old Feb 24, 2004
torqen2k1's Avatar
torqen2k1 is an unknown quantity at this point
Compression test
I just took an engine compression test on my D17A1/2001 Civic LX. I have 39,000 brutal miles on it and 42,000 totale. And yes I did break it in for a good 3 thousand before it started to see redlines for the next 39,000 thousand. I started to use Mobile1 non synthetic 5w/30. I changed the oil evey 3 thousand if not earlier. Cylinder 1 compression is -135- PSI. Cylinder 2 compression is -135- PSI. Cylinder 3 compression is -130- PSI. Cylinder 4 compression is -130- PSI.
1 2 3 4
135 PSI..135 PSI..130 PSI..130 PSI..
What does a brand new D17A1 have for a compression.
Old Feb 24, 2004
Elite's Avatar
Elite is an unknown quantity at this point
why dont you call and ask honda
Old Feb 24, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
yea i want to know about this too.
Old Feb 24, 2004
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
Those reading are normal if they were dramatically different then you would have a problem but 130 and 135 psi is not a big difference
Old Feb 24, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I did mine as well a couple months ago on a d17a1, and got 135 - 132 across. It's supposed to be 135, so your readings are perfect. Any variation of 28psi needs to be serviced.
Old Feb 24, 2004
C2i0v0i1C's Avatar
SuperMODrizd
did u just have spare time, or what, did u just wonder about it and do it
Old Feb 24, 2004
Boosted2k2's Avatar
I did mine for obvious reasons. Just to make sure the engine wasn't taking a beating from the turbo.
Old Feb 24, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i was referring to the original poster, i know you and me have a reason
Old Feb 25, 2004
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
Is it free under warranty to check them..or how much would they cost..?
Old Feb 25, 2004
Boosted2k2's Avatar
Are you talking about a compression test? It's the easiest thing in the world to do.
Remove the spark plugs, screw the compression gauge line into the spark plug socket, and crank the engine for about 4 revolutions, take the highest reading. Move onto the next cylinder. Takes less than 10 minutes. And it would cost less to get a compression gauge than to go somewhere and get it done probably.
Old Feb 25, 2004
torqen2k1's Avatar
No, I was just bored at school so I just wanted to see how much wear and tear my motor had from me redlinin it every day.
Old Feb 25, 2004
C2i0v0i1C's Avatar
SuperMODrizd
what school, college, UTI maybe
Old Mar 31, 2004
ImportRacer2123's Avatar
K20 Member
should the compression be the same for a D17A2?
SimpleUser
Apr 24, 2021 02:54 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
martinsmartin
Aug 15, 2015 07:34 PM
darwin-t
Aug 15, 2015 10:51 AM
fred57
Aug 1, 2015 08:45 AM
