Throttle cable affects MPG ??
Old Dec 30, 2001
CrEePin01CiViC's Avatar
CrEePin01CiViC is an unknown quantity at this point
I just adjust my throtle cable the other day. It is tight, i like it better like that. But I was wondering, does adjusting the cable his any affect on my MPG...Gas Millage ?? Good Question huh ? Cause I notice gas went down a little quicker or was it cause I was Creepin a little to long, the stop and go and stepping on it , gunning my Civic down the quarter mile over here ? Fill me in guys.....Im curious cause if it does affect my MPG im gonna change it back to factory!![IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 31, 2001
01civicboi's Avatar
01civicboi is an unknown quantity at this point
if ur mpg does go down, it's cuz you've been having too much fun with ur shortened cable [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 31, 2001
antidote11's Avatar
antidote11 is an unknown quantity at this point
Yeh...it's not the cable adjustment that brings the miles down, it's the your acceleration from gasing it : )
Old Dec 31, 2001
Grey's Avatar
DIY King
Well, actually... If you raised your idle rpm's then you're using more gas now while idling, so of course you're going to use more gas. If you haven't changed the idle rpm's (it should be about 600) then it's all your fault. You're a maniac driver! [IMG]i/expressions/laugh2.gif[/IMG]
Old Dec 31, 2001
cwick187's Avatar
cwick187 is an unknown quantity at this point
Yup!!!! When I bought my intake and adjusted my throttle cable, I noticed that my MPG went down alot!!! It's just because I started getting up on it to hear the intake though[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 31, 2001
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
it doesn't direcetly...but because of the shortend cable you will be giving it more gas
Old Dec 31, 2001
02Si's Avatar
02Si is an unknown quantity at this point
Answer: No unless you over tighten. Result of tightening it in the first place to give a better pedal response.
Old Jan 1, 2002
nbpEMCivic's Avatar
No...when you do this mod all you do is reduce the slack on the cable, therefore little effort is required from the driver's foot on the pedal to open the throttle. Not aware of this, most people will still press down on the gas pedal with the same pressure as they did before the "mod", therefore resulting in more gas being used, wich leads to the lower than average MPG.
mgrantaz
General
May 2, 2022 05:40 PM
Tyler93
Mar 20, 2016 09:03 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
John2009
Sep 10, 2015 09:53 PM
Bricoleur
Sep 9, 2015 12:30 PM
