if i change my cai to a sri .........
Old Dec 26, 2001
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
rite now i have a cai ... and so if i remove the bottom half of the piping, would i get the same response as a sri ?..... the cai and sri's diameter are different .. would it matter ?..
Old Dec 26, 2001
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
the asnwer to ur questions is YES
Old Dec 26, 2001
1973's Avatar
1973 is an unknown quantity at this point
if you mean performance response, then no.....cai is much more effective because it draws in colder air than an sri...the density of colder air means better combustion, which equals more hp...for every 10 degrees celsius you remove from your intake temp you get 1 hp....on a 25 degree day you will usually find that your intake temp with an sri is about 120 degrees, because of the heat under your hood....on the same day with a cai your intake air temp should be around 80-90 degrees which equals 3-5 more hp than a sri. on 30+ degree days you will probobly find that you are loosing hp from your stock numbers with an sri because of hotter intake temp, thats why honda puts the stock intake so far from the engine...in my opinion either go with a cai, it's probobly the best bang for the buck of any performance mod...you will see about 2-4 hp at the wheels, all the way through the rpm band....if not, drop in a k&n filter charger, good for about 1-2hp over stock and worry free.....[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 26, 2001
1973's Avatar
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]hey man, i just realized your from scarberia, my brother (97 civic hb) just moved up his cai to an sri for the winter, accordind to him his car feels much better than it had over the past month...what we figure is that in the winter when the intake temp of a cai is super low, it may mess with your computer, which might not understand an intake temperature of 0 degree's celsius, its just a guess.....so summer cai winter sri....easy!!!!!!!!
trevor
Nov 16, 2001 05:02 PM
trevor
Nov 15, 2001 05:59 PM
se7en
Nov 12, 2001 10:13 AM
Daniel420
Nov 9, 2001 08:36 PM
PlatnumBomb
Bolt-on Engine Performance
Nov 9, 2001 01:11 PM
