Check Engine!! light on after installing SRI..help!!!
Old Dec 29, 2001
black's Avatar
black is an unknown quantity at this point
I hooked the black thingy back into the other thingy... and the other black thingy into the other black thingy, anyone know what it might be?!!! [IMG]i/expressions/face-icon-small-confused.gif[/IMG] [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Dec 29, 2001
STYLIN2K2's Avatar
STYLIN2K2 is an unknown quantity at this point
YEAH IT MIGHT BE THTA BLACK THINGY THAT YOU PLUGED INTO THE OTHER THINGY
Old Dec 29, 2001
black's Avatar
So what should I do? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 29, 2001
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
It might just be your ecu telling you that the air/fuel mixture is not normal. Since now you're getting more air than you used to. It takes the ECU a while to reset itself. OR you can do it by disconnecting the neg terminal off the battery for 15 seconds. If that doesn't solve the problem, then it was the black thingy.
Old Dec 29, 2001
bobbyd's Avatar
bobbyd is an unknown quantity at this point
if your using a K&N or another type of reusable air filter make sure that you don't have it so oily that the oil sucks through the tube and ruins your temp sensor.
Old Dec 29, 2001
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Yeah, just reset your ecu . I had the same problem.
Old Dec 29, 2001
1973's Avatar
1973 is an unknown quantity at this point
if you can't reset the check engine light by unhooking your battery, then i hope your're due for an oil change! get your car into honda as soon as you can, just tell them your check engine light came on...don't tell them it happened after you installed your sri...ask them to check the error code, it will tell them exactly what the problem is, they won't charge you for this as long as you do it while you're getting other work done...its probobly nothing and they will reset your ecu for you, takes two seconds, or they will tell you, that you have some sort of problem and then you can decide how you want to take care of it from there...... if you think you might have messed up a sensor, then put your stock box back together and make the whole set-up look like you never took it apart, then go to honda and play dumb....they will have to fix any problem under warranty.....
Old Dec 29, 2001
2k1Vtecivic's Avatar
2k1Vtecivic is an unknown quantity at this point
make sure it is not ur gas cap since am the one that check the engine lights at honda of san diego and most of the time its the cap
Old Dec 29, 2001
black's Avatar
Awesome guys, tomorrow I will try disconecting the negative terminal battery thing.. I also read before something on reseting the ecu by messing with the ecu itself? [IMG]i/expressions/face-icon-small-confused.gif[/IMG] I will just do a search through the forums to see what I find... lol.. that would suck if I had to put that big black box back in.
I know I had put on the SRI correctly at first and used it with no problem for three full days..
however I baught a new set of tightners so the rubber holder part would be super tight..
and thats when i disconected that black electronic plug..
right after.. I started the car with it NOT connected.. saw the check engine, realized I forgot to plug it back in right away
.. but didnt think it'd cause such an effect...
Guess thats that eh? Or am I confused?
hehe Thanks once again guys. And Happy Holidays! [IMG]i/expressions/beer_yum.gif[/IMG] [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
