Help with homemade induction on 04 EX.
Old Mar 31, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
The air filter box lays flat over the throttle body and theres no way (yet) to add an intake diret to it as you could on the sideways throttle bodies. I have a piece of PVC that fits pretty snug into the filterbox hole. When i add the intake tube and filter theres some up and down movement because there is a 45 degree elbow coming out of the airbox and its attached to the intake tube and filter that goes behind the battery. If i dont secure it it will eventualy slide out of the box so i fixed that by adding a set screw on the inner part of the PVC just after it goes into the box to keep it from moving out. My problem is since theres some up and down movement it rattles. If I secure it to a bracket somewhere it doesnt move th the movement of the enging and still rattles. Any ideas how i can secure this thing? I was thinking of gluing it into the opening but if i ever want to go stock im screwed.
Old Mar 31, 2004
Spider883's Avatar
9K Redline Owns U
I smell some rice cooking
Just buy an actual intake please
Old Mar 31, 2004
024drlx's Avatar
024drlx is an unknown quantity at this point
why?! come on man, do what majority of people on this forum do, save up to buy the product you want.
Old Mar 31, 2004
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
yeah go save up $200 for a 'real' intake. you'll probably get more power outta the home-made thing due to the fact that its plastic and wont absorb so much heat. what's wrong with pvc pipe? it can be painted with a little custom work it could actually turn out pretty good. to asnwer your question. perhaps put some cushioning around the pipe that goes into the hole maybe like a silicone sleeve or if that too thick wrap it with some tape or something a few times to give it that extra thickness. just an idea
Old Mar 31, 2004
redvtec04's Avatar
VTEC MASTER
The small part going into the filter box is PCV. The rest of the unit was purchased at Autozone and its the real thing. The only drawback is that its nor directly connected to the Throttle body.
Old Mar 31, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
ooooo i did this toooo
i used zipties to tie the end of the tube to one of the cables (positive battery). itll hold it up.
my pipe was just a replacement of the resonator box, using botht he stock airbox/filter and inlet tube.
there is actually a growl-type sound when i get on it. and there seems to be no power change from stock. plus, you can say you made it
Old Apr 1, 2004
dru106's Avatar
ThE CoRRupToR
OH SH IT!!!!! I think the rice is burning............
Old Apr 1, 2004
RMSIHPA's Avatar
RMSIHPA is an unknown quantity at this point
hell i make custom intakes i'll sell you one cheap. just put the rice down and back away we dont wont anyone hurt.
Old Apr 1, 2004
robbclark1's Avatar
Retired suspension supermod.
I have a custom intake. And though it isn't great, it does the job. PLEASE DO NOT USE PVC!!!! It can burn and give off noxious fumes!! Use steel exhaust piping.
Old Apr 1, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I'd be more worried with the fact that it cracks real easily when it gets below freezing, but I guess noxious fumes is bad too. Use glass filled nylon, ABS, polycarbonate or something. or better yet, OEM rubber-type stuff. I'm not sure what its going to do anyways... the filter in the box is so tiny, that the majority of whats choking the car up.
I'm still working on mine... but mine's about as far from ghetto as you can get it, OEM parts aren't rice.
Old Apr 1, 2004
PunkingCivic's Avatar
I need TP for my bunghole
without pics it is hard to help.
just buy a cheap 20 dollar intake from ebay
Old Apr 1, 2004
Liro's Avatar
Back from the dead
i dont get it...why is this necessary? just buy an intake...ur better off leaving it stock than getting rice in the engine....
Old Apr 1, 2004
zoom04's Avatar
zoom04 is an unknown quantity at this point
check, sup with this 24$$$ CAI that u see in ebay r the any good they say it will give up to 15 hp
Old Apr 1, 2004
skarteez's Avatar
hey boilermaker, you done with that ITR intake retrofit yet?
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
Raiool
Oct 1, 2015 10:42 AM
Balkos
Sep 11, 2015 11:39 PM
msaeger
Sep 2, 2015 08:47 AM
