Rear lip starting to gap with heat
Old Jun 27, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
Angry Rear lip starting to gap with heat
when i first installed my xenon (urathane) rear lip about 3 months ago- it looked perfect. all the seems fit just fine, there were no gaps along the top part where the lip edge meets the bumper. Little by little, gaps started forming around both ends. Now- its getting hot as hell in CT (hot as hell = 93 F), the gaps are getting wider and wider. what should i do??? can i get some sort of glue to fill it in and hold it? or should i take it all off and start over? the tape the lip came with looked like it was good stuff, it was red 3m tape, it came with this adhesive promoter too.
Old Jun 27, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
Id re-do the whole thing. I don't know if I'd try to fill the gaps with glue, might look like crap.
Old Jun 27, 2003
wonderz's Avatar
wonderz is on a distinguished road
how does redoing help? if the damage is done..its done. maybe buy one of those car covers to put it on the car if you are leaving your car out in the sun for a while..
Old Jun 27, 2003
bamb00's Avatar
You should post a pic and we can figure something out.
Old Jun 27, 2003
wonderz's Avatar
yea, a picture will help. I have an idea. Maybe you can use something to clam the bumper to the lip and leave it out in the heat or use a heatgun or blow dry to heat that section up, so that the lip will go back to its original shape.
Old Jul 11, 2003
jameswyatt's Avatar
jameswyatt is an unknown quantity at this point
dude i had the same problem with mine , what you do is take it off and remove all the old tape and add some new(don't forget to put on the promoter)and try installing it up alittle higher, it worked for me>
Old Jul 11, 2003
SOHC's Avatar
thanks, yeah- that does make sense, thanks!
leon1
Apr 28, 2015 07:32 PM
cooldan1
Apr 23, 2015 10:49 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
