Headunit Installation in pocket
Old Jun 28, 2003
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
The part im talking about is that part beneath the arm rest, its a little box with a slide door... hope you guys know what im talking about
Anyways I want to install my headunit there and was wondering if it is a difficult job to do???
and how about would I be doing this?? Can someone give me a brief DIY??
thanks
-Alex
Old Jun 28, 2003
Samari's Avatar
Alot of wires and splicing and some good handy work!
Old Jun 29, 2003
DizWikedCivic's Avatar
it seem pretty easy, just extending the wires, and cutting and screwing it down
Old Jun 29, 2003
WhiteRabbit's Avatar
i wouldnt expect to be able to keep your sliding door.
as far as i can tell, i pioneered this idea, by building my own console. another member here did it keeping the stock panel, i chose to go custom because I didnt believe you could physically fit a radio in teh stock location, due to the structure of the e-brake.
i believe he modified his e brake housung, cut some out, he had to do something. his looks really nice, and the stock change holders are far more handy than the ones i added to my own panel.
try posting in ICE, to grab his attention, i really am not sure exactly what he did to retain the stock panel.
what i would count on, however, is that you will lose the function of yrou sliding door. theres jsut not enough depth in there to fit a radio very deeply.
Old Jun 29, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
what i did was use half of the pocket. i used the half that was closer to the e-brake. i duct tapped my headunit to that. and the half of the pocket that i used has holes that screws onto the trim peice that u see ontop. the e-brake bracket must be cut a lil bit to fit the headunit.
if u used a aftermarket headunit the opening will not be big enough for the faceplate. so u either have to cut up the opening so it will fit, or wire your faceplate into the ceiling like me
and i think whiterabbit was the pioneer of this.. props to you and that other guy that helped me with the faceplate ceiiling thing!
OptimisticWay
46
Oct 15, 2015 02:16 PM
EM_WON
Jul 22, 2015 06:49 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
