injector question
Old Sep 24, 2002
prototype's Avatar
x-factor
injector question
is it safe to run bigger injectors at a lowwer psi? i wanna get bigger injectors for future mods and dont wanna break n e thing...i also have a s-afc
Old Sep 24, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
lower psi... do you have a turbo? Because you'll never need bigger injectors with a normally aspirated (no turbo or supercharger) setup. You might with a larger nitrous setup, but most likely not.
You can run any injector that will fit, as long as you use the S-AFC to tune to a proper air fuel mixture. With larger injectors, you'll have to run them at a reduced duty cycle, which the S-AFC can do, to a point. Just make sure the S-AFC can reduce the fuel map enough to compensate for the larger injectors. My advice would be to wait until you really need them before you install them.
Old Sep 25, 2002
prototype's Avatar
x-factor
ok so if i have intake header exhaust, cam. cam gear, fuel rail, nos, s-afc, running bigger injectors wont help?
Old Sep 27, 2002
themi6group's Avatar
themi6group is an unknown quantity at this point
Quote
[hr]Originally posted by: osofast2001
ok so if i have intake header exhaust, cam. cam gear, fuel rail, nos, s-afc, running bigger injectors wont help?[hr]
more fuel always helps, as long as you have proper fuel tuning. you don't need to go too large on injectors, maybe just 280cc or 310cc saturated. stock you're at 240cc which is plenty. you otta save your money until you get a much more serious setup.
SimpleUser
Apr 24, 2021 02:54 AM
SuperNova18
24
Sep 2, 2019 10:46 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jody501
Jul 10, 2015 11:01 AM
