Something Crazy
Old Jun 9, 2003
kbradner's Avatar
kbradner is an unknown quantity at this point
Question Something Crazy
I just got done hooking up an alarm in my 01 civic now my air condition wont come on neither will the heater. Any suggestions?
Old Jun 9, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
check fuses
Old Jun 10, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
fusses or wiring, where did you hook your power and ground wire???????
Old Jun 11, 2003
kbradner's Avatar
Well I fixed it now, my dumb ***, when I put the wire for the horn threw the hole in the firewall i guess when I was pushing it threw I slpit the wire to my A/C and Heat in half so I had to get down there and wire it back up. It sucked !
Old Jun 11, 2003
4jacks's Avatar
I just used the hole behind the brake pedal,
Where did you find the hole with the A/C and heat wire ???
Old Jun 11, 2003
kbradner's Avatar
If you look under the passenger side dash in the floor board almost. Its got about 40 wires in it, then there is a rubber gromet. I didnt know there was a hole behind the brake pedal I might have to rewire everything if itll look better, its kinda all bunched up right now in the same spot.
Old Jun 12, 2003
4jacks's Avatar
Ah ha.. i'll have to take a look at that. .. .
underneath the brake pedal, kinda inbetween the brake pedal and the clutch, you will see like a plastic plug, pop that out and you will see a hole in the firewall.
There is a spot to the left to feed the wires through, so you can put the plastic plug back on.
Old Jun 12, 2003
HomerSimpson's Avatar
I didnt want to mess with anything already existing, just drilled a new hole.
Old Jun 12, 2003
kbradner's Avatar
Well Ill have to find that hole and rerun all my wires.
Hooonigan
Sep 6, 2015 06:15 PM
jonwalden68
Aug 27, 2015 12:07 PM
mac25
Aug 21, 2015 11:14 PM
adamdrives
15
Aug 8, 2015 08:53 PM
suburbanite
Jul 17, 2015 03:05 PM
