HELP: Adjusting Front Toe
Old Jun 11, 2003
Grey's Avatar
DIY King
How the hell do I do it? I jacked the car up. I took off the wheels. I took the tie rod ends out of the shock absorber assembly. Now what? I can't seem to get anything to turn. Maybe it's just rusted shut, but which way do I turn to loosen it? There seems to be some sort of a nut that locks down the tie rod end. It seems to be a right-hand screw. Am I thinking about this the right way? I'm just stuck 'cause I tried turning everything every which way and I can't get things loose...
Old Jun 11, 2003
Grey's Avatar
DIY King
Nevermind. I got it. You had to leave the tie rod end in the shock absorber assembly and then loosen the locking nut. Then you simply turn the whole tie rod to adjust the toe. Easy.
Old Jun 12, 2003
solar's Avatar
solar is an unknown quantity at this point
How are you setting the toe? Do you have a machine, or a couple of turn tables, string and a tape measure? Just wondering.
Old Jun 12, 2003
Grey's Avatar
DIY King
Two turn tables an a microphone! LOL
No, actually... Just string. I did it wrong the first time though. It seems that the toe changes when the car is in the air and when it's down on the ground. I have to re-do it. I'll re-do it with the wheels on and somehow get it right. Wish me luck... As it stands now I have massive toe out. LOL
Old Jun 12, 2003
Grey's Avatar
DIY King
It's done! The steering wheel is straight again and the toe is at 0 on both sides. That's measured with a string when the car is on the ground with me not in it. It works though. The car tracks straight and it feels lighter. Makes sense since toe in or out kinda makes the steering feel heavy.
Old Jun 12, 2003
Zzyzx's Avatar
Autocross Junky
thats bump-steer.
0 toe is a good setting, alot of autocrossers have 0 toe to a little toe out. It helps with initiating turns.
Old Jun 12, 2003
Grey's Avatar
DIY King
What do you mean bump-steer? They make the suspension like that to counteract bump-steer?
Old Jun 12, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I'm curious Grey, how did you use string to measure toe? I am about to head out and replace my ripped tie rod boots so I'm glad you posted on how to remove them easily you think it would be accurate just to count the number of threads showing on each end before removing the old tie rod end, and fix the new tie rod end in the same spot?
Old Jun 12, 2003
Grey's Avatar
DIY King
What I did was basically rely on attaching a string to a point that lies on the imaginary parrallel line that runs through the center of both wheels on one side of the car. So... I attached the string on the rear wheels at the point that's the furthest from the front of the car. Then I ran that string all the way to the front wheel to the point that's the furthest from the rear of the car. This method relies on the rear wheels having 0 toe, but since the line is at the furthest point even if they do have a little toe in or out, it won't affect the front toe as much.
If you want to replace your damaged tie rod end, the simply do this... Un-screw that one nut (without removing the tie rod end). Then screw it back on loosely. Then unscrew the tie rod end without touching that one nut (it'll be a sort of place holder for you when you attach the new tie rod end. Then just remember which way the bolt on the tie rod end was facing when you took it out since I think there's a way to screw in some threads where they end up 180 degrees flipped. Should be pretty easy.
Old Jun 12, 2003
Zzyzx's Avatar
Autocross Junky
ok, Can-o-Worms time.
The book definition of bump-steer is "Toe change due to suspension compression/expansion"
what it means is when ever your suspension compresses (reaching the bottom of a hill for example) the suspension compresses and changes the toe of the car at that instance. how much and when is determined by the placement of the steeringrack and how/where it attaches to the suspension. Honda claims to have eliminated bumpsteer by placing the steeringrack High in the engine bay. (Most cars have the rack mounted low) This however does not get rid of bumpsteer, it just changes what it does. With most cars(Steering rack mounted low) when the suspension compresses, it causes toe out. Toe out will make the car unstable and possible uncontrolable if it is excessive. With our cars, suspension compression will cause toe in makeing the car want to go in a straight line.
The Problem lies in Geometry. The front wheels do not move directly straight up or down when the car hits a bump. Instead, the wheel follows an arc, or curving path, that pushes the wheel slightly inward (towards the centerline of the car) or outward (away from the car) in response to vertical wheel movement. The outer tie-rod (which connects the steering rack to the wheel) also moves in-and-out in an arc as it moves up and down. If the rate which the outer tie-rod arcs in or out does not match the rate the wheel moves in or out, the wheel will be turned by the tie-rod. This is bumpsteer. The center point of the arc traveled by the wheel (known as the instant-center) is controlled by the location and angle of the moving suspension links. This point moves as the ride height changes. In contrast, the arc of the outer tie-rod is controlled by the position of the steering rack, which is fixed.
Old Jun 12, 2003
Grey's Avatar
DIY King
Ah, ok. Thanks. I get it now.
Old Jun 12, 2003
solar's Avatar
Good job man!!! I used to make about a $100 every Saturday night setting the toe on the "roundy round" cars at the Speedway at $10 a pop. All I had was 2 turntables, string, chalk, tape measure, and a jack.
Old Feb 11, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
wuts a turntable? i'm sure it isn't the DJ stuff is it?
Old Feb 11, 2004
Zzyzx's Avatar
Autocross Junky
Its a platform designd to support one of the wheels on a car but still alows that wheel to be turned and adjusted while the suspension is still under load, allowing for proper alignment.
Old Feb 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
turntables also allow the suspension to settle to its normal static position
Old Feb 11, 2004
§C§H§O§C§O§B§O
ahh i c...will need 2 of those to go proper adjusting? 1/front wheel?
Old Feb 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
for proper adjustments you will need two turntables(1 for each side) for the front, and the rear will need to be at the same height as the front. So they too will need to be raised to the same height as the front. And if you plan on adjusting the rears they make a cheape form of this its called a slip plate. Average turntables go for around $500 for a pair giver or take, its been a few years since ive bought some.
BootyDo
Jun 21, 2016 03:45 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Jul 12, 2015 11:54 AM
Ccoop87
Jul 9, 2015 03:26 PM
tomg
May 21, 2015 07:05 AM
