spark plugs=better gas economy: why?
Old Jul 18, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
i was reading a thread where people talked about the upgrade to Bosche platinum +4 spark plugs and had better gas economy because of it. I would like to know what does the Bosche have over our factor plugs. Why does it create better gas economy? more sparks or better timing or some other factor???.....thanks guys for any help
Old Jul 18, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
The more spark the more efficient the combustion. The ECU will accomodate for this better combustion by lowering the fuel pumped into the chamber. Therefore, better gas mileage.
Old Jul 18, 2002
Jon's Avatar
Jon
succinct and sweet thanks
Old Jul 18, 2002
Strider's Avatar
Strider is an unknown quantity at this point
cause i'm kinda at work now and too lazy to go to the car place after work... about how much are those spark plugs running for (cost)
and yes, i know this is going to be a complete newbie question, but we need four spark plugs right?
Old Jul 18, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
Like 5 bucks a plug for the Bosch 4+ and I have the Bosch 2+and I think the bill came to like 15 bucks with tax
Old Jul 18, 2002
Yes, you have as many spark plugs as you do cylinders. Except on the RX-7. There are two rotors and four sparkplugs. Two leading and two trailing.
Hey AirForce, why do you have my girlfriend in your sig?
Old Jul 18, 2002
Jon's Avatar
Jon
hey silverdevil, can you explain why on the RX-7 there are 2 leading and 2 trailing spark plugs??
edit: what does Bosche mean by +2 and/or +4?? what is the difference in the two and what makes one necessarily better than the other?
Old Jul 18, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
dude bosch +4 sparkplugs suck!!!! the only good thing that i like about them is theyre good w/ nitrous. otherwise, they suck!!!they reduce your gas mileage. and makes your engine sound a little rough
Old Jul 18, 2002
symmetry's Avatar
symmetry is an unknown quantity at this point
Quote
[hr]Originally posted by: civichx81
dude bosch +4 sparkplugs suck!!!! the only good thing that i like about them is theyre good w/ nitrous. otherwise, they suck!!!they reduce your gas mileage. and makes your engine sound a little rough[hr]
I had this same problem in my 94 tegra and 86 prelude. I won't even consider putting them in my civic. To much respect for my car.
Old Jul 18, 2002
Quote
[hr]Originally posted by: Jon
edit: what does Bosche mean by +2 and/or +4?? what is the difference in the two and what makes one necessarily better than the other?[hr]
1. The rotor has two stages of compression and one stage of Intake/Exhaust. The rotor looks like a triangle. The first stage of combustion is the leading and the second is the trailing. The rotors spin counterclockwise so the leading sparkplug is on the bottom and the trailing in on the top. The Rotors are perpendicular to the tires, they go from side to side, not front to back. It's easy to remember where to put each sparkplug because they are marked L and T for leading and trailing, or Lower and Top. They are idiot proof. The exhaust is on the passenger side of the vehicle.
2. The +2 and +4 comes with how many prongs are at the bottom of the sparkplug. I forget the real name for them. But regular sparkplugs have one, the +2 have 2 and the +4 have...You guessed it, 4!
PS. If you've never seen a rotary sparkplug, they are cool. They don't have the prongs like regular sparkplugs, the tip is sunk into the body of the sparkplug and it has four slits. Very different.
freyes23
Jun 21, 2015 10:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
TopFuel
Jan 26, 2002 06:03 PM
MikeyBoy
Jan 26, 2002 06:45 AM
