green plug when installing my intake?..wat the?
when i removed my stock airbox there was this green plug i had to disconnect from it...and when i put on the new intake i forgot about it...it drove perfectly normal..but i just rememberd bout it and i duno where the hell it plugs into..and what it is...some1 help meeeeee
you mean your o2 sensor? well you proly should plug it in because you're not getting an accurate reading because the engine might be different than the air you're getting from your intake.. it's to the right of the throttle body right?
Don't worry, its just a clip that goes on to the back of the baffle box, next to the air filter box. It does nothing except to hold a wire against the box. I wouldn't worry about it at all. Nothing bad will happen to your car.
Escaped Convict
its usually refer to as the MAS or air temp sensor or what not..
it sense the amount of air going into the throttle body.. and the air's temperature...
without it, what aftermarket intake claims wont work at all... as the ECU wont read the extra flow of air and adjust the fuel mixture accordingly...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
danace99
23
Jun 28, 2015 08:49 AM
