proper throttle cable adjustment?
Old Jul 13, 2004
Anyone know what the factory setting is for the throttle cable? I think mine's loose, but I don't want to tighten too much and then have it come apart. And where is the cable, next to the TB?
Old Jul 13, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I've already adjusted mine twice, and I'm at around 23k. It's very easy and shouldn't take more than ten minutes. The cable comes from the right, and runs parallel behind the valve cover. There are two nuts around a threaded sleeve, one on each side of a bracket. Simply adjust the side on the left, then tighten the side on the right of the bracket to keep it in place. Expect to adjust it once or twice to get it right. Just adjust it, turn on the car and make sure you didn't raise the idle, and check the pedal slack.
Old Jul 13, 2004
djmota's Avatar
cable deflection should be 10-12mm
Old Jul 13, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Actually.... the RIGHT adjustment for the throttle cable is to have someone floor the pedal, and then adjust the cable looking at the buttefly in the throttle body. The butterfly should be wide open without putting extra tension on the cable.
That would be the right way, so the cable does not get stretched.
Though I rarely do things the "right" way.
Old Jul 13, 2004
Sickboy's Avatar
You better hope the butterfly stroke and the pedal stroke are equal then. And, why are you worried about stretching that cable? It's thicker than my mountain bike's disc brake cables and they take way more stress with zero problems.
Old Jul 13, 2004
tinman's Avatar
Actually, it's the pressure you put on the throttle body linkage that's bad in the long run.
As I said, the "RIGHT" adjustment. Honda leaves it loose anyway. Though I agree, I hate play in the throttle myself.
Old Jul 14, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
just a quick question about this throttle body stuff, I also read the DIY thread about it. If honda does realize that you played with the cable and tightened it for better throttle response could they void your warrenty?
Old Jul 14, 2004
I doubt they'll know unless it breaks from being too tight.
Old Jul 14, 2004
NaSh123's Avatar
I see. Can you actually feel the difference from adjusting it? Is it worth the work? or no?
Old Jul 14, 2004
It will just make the car get off the line quicker when you step on the gas. I'm not tightening it past the normal specs. Someone had theirs break while driving because it was too tight.
Old Jul 15, 2004
Sickboy's Avatar
You guys are killing me. It's a metal cable that stretches, just like your e-brake cable, just like my mountain bike cables. I think adjusting these is even part of Honda's "10k mile overpriced service." It's routine maintenance, not a warranty-ending modification. If the throttle body linkage is so weak that a few lbs. of foot pressure on the gas pedal would bend/break it... and I've never heard of this happening... no more Honda for me.
Old Jul 15, 2004
NaSh123's Avatar
just wasn't sure so I thought i'd ask. heh better to be safe than sorry
Old Jul 16, 2004
Skellz's Avatar
Skellz is an unknown quantity at this point
There is a DIY that DEREK- CEO Posted works well with pictures. Check it out.
Dani1993
Jul 24, 2015 09:02 AM
Dave1984
Jul 22, 2015 06:10 PM
Jul 12, 2015 11:54 AM
muttleytm
Jul 11, 2015 06:00 PM
Ccoop87
Jul 9, 2015 03:26 PM
