H E L P--Engine Maintenance Required Light
Old Jul 6, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Unhappy H E L P--Engine Maintenance Required Light
I just hit 35000 miles and the engine maintenance required light went off... I just flushed my transmission fluid twice today but that didn't do it, I know I'm suppose to do it 3times, but the 2nd time the oil is pretty clean, I will probably flush it again tomorrow if I got time, and I'm getting my oil change tomorrow aswwell and will this eliminate the maintenance required light?
I tried unplugging the ecu fuse and taking out the negative battery terminal for about 30mins to restart ecu, but that didn't work
does honda have to connect it to their computer and reset my ecu? do they put a data to the ecu so that it would make the maintenance required light to go off every 35k, 70k, 105k and so on?...
Thanks you guys, i'll be searching online aswell just incase they mentioned this before!
Old Jul 6, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
This definately has been "mentioned" before. Read your owner's manual. I think you have to hold down the odometer button while you turn the ignition on. Something like that.
Old Jul 6, 2004
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
Yeah for a maintenance light, it just involves holding down the trip button for a certain amount of time. Don't remember exactly, but its something like holding down the trip button and then turning your key to position II on the ignition and holding on until it disappears.
Old Jul 6, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/se...searchid=85743
do what isra says. It will get rid of it. Have you never noticed it before? It comes on every 8 to 10k or so. Or have you been taking it to the dealer where they will reset it for you? Locked. Search for +maintenance +light in advanced search if my link doesn't work.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
doncarbone
Jun 8, 2015 03:37 PM
Caligirl
May 29, 2015 08:01 AM
supercivic01
South
Nov 30, 2001 11:27 AM
