Aftermarket Shift Knob...
Old Aug 3, 2002
Kapriccio's Avatar
Kapriccio is an unknown quantity at this point
Aftermarket Shift ****...
I would like to change my stock shift **** (on a manual sedan) for a Momo King Aluminum or similar; however, I would like to know how would I go about holding the boot up. The stock **** has some sort of clips for the silver ring, which keeps the boot up. Thanks for your advice.
Old Aug 3, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I am planning on going with a Momo shift **** too...what I am doing is buying the shift ****/shift boot system from Momo. The shift **** will screw right into the shift boot. But if you don't want to spend all that money, try and get a rubber bushing, slide it onto the shifter below the top of the shift boot or get some black cable ties...that should work....
2Hottie
Old Aug 3, 2002
riceboi's Avatar
riceboi is an unknown quantity at this point
momo also makes a ring for the boot.
i've got a momo w/ the ring - looks good
Old Aug 3, 2002
Kapriccio's Avatar
Thanks 2Hottie, how much for the Momo shift boot? An where?
riceboi: where did you get the boot ring and how much? Sounds like a very good and simple solution.
Old Aug 3, 2002
riceboi's Avatar
momo shifter w/ ring
Old Aug 3, 2002
riceboi's Avatar
the retailer that you buy the **** from should have the rings as well.
i've got an extra momo boot if you want. new, w/ packaging and everything.
Old Aug 3, 2002
Kapriccio's Avatar
Hey riceboi. That shifter look awsome! That is exactly how I would like mine. Hopefully I can find the ring, Thanks for the tip.
Old Aug 3, 2002
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
i know a lot of people wrap black electrical tape around shift pole or whatever its called that the boot covers
Old Aug 3, 2002
2Hottie's Avatar
Quote
[hr]Originally posted by: Kapriccio
riceboi: where did you get the boot ring and how much? Sounds like a very good and simple solution.[hr]
The shift boots you can usually find wherever you buy the *****...there is a place around here I can get both of them for like $120...not too bad
2Hottie
Old Aug 4, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
here's what i did and it only cost me $3. go to your local home depot or OSH and buy a spring slightly larger than the diameter of the shaft of the shifter. slide the spring over and down the shaft, you might have to cut the spring depending on it's length. the spring will push up the silver ring against the ****. i patented this idea so you must send me money if you want to use it .
Old Aug 4, 2002
Kapriccio's Avatar
Hey guys, I just went with riceboi's setting, and ordered the King Aluminum Shift **** and the Finishing Ring ($16+S&H). I think it looks nice, and if I'm already spending $70 on the shifter, I might as well finish the job with the Momo Finishing Ring. I just hope I don't have any problems with the installation. Thanks.
Old Aug 12, 2002
money9's Avatar
money9 is an unknown quantity at this point
Oh yeah, perfect.
Can you explain exactly how it works, just so I have an idea. It looks as though it is the original boot from your Honda. How does the ring connect to the boot.
Looks like an alternative that would work great for me.
Cheers [IMG]i/expressions/beer_yum.gif[/IMG]
h4ldol
Apr 24, 2017 08:16 PM
Tyler93
Mar 20, 2016 09:03 PM
danace99
Oct 17, 2015 02:51 PM
bhollie
Sep 22, 2015 11:08 PM
Jrosa
Sep 14, 2015 08:24 PM
