brake lights dont work
Old Aug 23, 2002
VNlilMAN's Avatar
The Standard One
i didn't have a clue where to put this cause it doesnt exactly belong in the wheel/tire/brake or ICE so its here...
and this isn't my car but my friend 99 accord but same difference...
its what the title says, the rear brake lights dont work. the 3rd, middle light does tho. the bulbs arent burnt either cause it turns on when the headlights are on. we even replaced the bulbs. also checked fuses... any other idea?
Old Aug 23, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
This is funny... The same thing happened to my dads Explorer. The 3rd light worked but both brake lights went out at the same time. But the tails still lit up. I forget what it was, there was somekind of connector or something in the wiring that needed to be changed, and it blew both brake lights. It was $60 bucks to fix it... that may be your best bet since you may/may not know where the problem lies.
Old Aug 23, 2002
VNlilMAN's Avatar
The Standard One
eh... if it was my car i would be tearing things up and eventually rig it to the 3rd brake like but its not my car so... worst thing is his warranty is up and i would hate for him to spend $60 on something that sounds so easy to fix.
Old Aug 23, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Man, that's weird. Obviously it's triggering the switch behind the pedal. Maybe take a wiring diagram and trace the wires and see where they split. There's probably a loose wire after the split.
Old Aug 25, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I think that you may have blown a fuse or something. It may not be the case because one of the lights does work, but you may want to check just incase. They are cheap to replace!
Old Aug 26, 2002
zero's Avatar
zero is an unknown quantity at this point
Is your car a auto or manual? If it is a auto and you can still shift, then you did not burn the brakelight fuse cuz if the fuse is blown you will not be able to shift into gear without using the shiftlock. lol I still don't know what is wrong with your car.
Old Aug 26, 2002
VNlilMAN's Avatar
The Standard One
ya its an auto... we still have no idea either..
Poopies
Apr 20, 2017 11:36 PM
ORskier
May 3, 2015 12:54 PM
McD
Apr 29, 2015 03:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
bsmiley
Apr 27, 2015 01:27 PM
