Install Door Speakers
Old Aug 8, 2002
Erik's Avatar
Erik is an unknown quantity at this point
How much of a pain is it to replace the door speakers in a 2k1 Civic LX Coupe w/ PL, & PW?
Old Aug 8, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
at first, like most things, of course it will be harder. You just need to know that are two screws behind the door lever, 1 big screw in the doorhandle, clips all the way around and after you pop out all the clips to hit the bottom of the panel off to dislodge it. Make it easier by unplugging all the switches. I can pop mine out in 5 minutes w/o rushing.
Old Aug 8, 2002
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
jus look at the DIY...at first it was long for me but like ASW said its easy now
Old Aug 8, 2002
mohawkboom's Avatar
tis a quick easy job....just be careful removing the plastic trim behin the door handle..their easy to scuff and such...
Old Aug 8, 2002
CarpeDiem's Avatar
CarpeDiem is an unknown quantity at this point
I watched the shop install mine...
the door was easy but the crossover and tweeters took a little more time..
Old Aug 8, 2002
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
It's really easy if you know where the screws are. the DIY here has the big info on it...
or you can check my pictures of me removing the door panel from mine here... maybe some of the pictures give you a diff perspective.
door speaker access pictures
The hardest part for me was hacking my existing speakers to make them mounts. This basically meant cutting out the exising speakers.
The tweeters are the easiest part, since they pull off completely if you cut the wires to be hacked to mount new tweeters.
Old Aug 8, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
I took out the speakers and drilled mount holes in my door. then I just used sheetmetal screws to hold it in place. Quick and simple.
Old Aug 8, 2002
Quote
[hr]Originally posted by: silverdevil
I took out the speakers and drilled mount holes in my door. then I just used sheetmetal screws to hold it in place. Quick and simple.[hr]
Did you have any problems with the magnet interfering with the window glass?
Old Oct 12, 2002
BronxCivic01's Avatar
BronxCivic01 is an unknown quantity at this point
What about Duct taping the speakers to the door?
Old Oct 14, 2002
I used duct tape. The speakers mounted on just fine. No rattling, no problems. Sounds great!!! Just an idea for some of you............
Old Oct 14, 2002
Bellz's Avatar
Quote
[hr]Originally posted by: BronxCivic01
I used duct tape. The speakers mounted on just fine. No rattling, no problems. Sounds great!!! Just an idea for some of you............[hr]
I REALLY hope that's a joke.
mistermenphis22
Apr 3, 2016 08:06 AM
Jeffdp
Aug 5, 2015 11:38 AM
Jeffdp
Jun 18, 2015 06:18 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
