bad struts?
Old Aug 24, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
bad struts?
i get a very loud slamming noise when i put or take my car off of jackstands. anyone know why? i have the car jacked in the proper points...
Old Aug 24, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
where do you put the jack stands?
jack the car up from the front....theres a jack point right behind the bumper cover...theres an arrow pointing to it. use that one...
Old Aug 24, 2002
yea i saw that and was using the proper points...any ideas?
Old Aug 24, 2002
have you hit anything with your front tires? curb? animals? people? (jk) you might've blown a suspension bushing...and the metal suspension peices are knocking together?
Old Aug 24, 2002
VNlilMAN's Avatar
The Standard One
at what point does it make the slamming noise? it get a noise but its not a slam, just regular suspension noise.
Old Aug 25, 2002
to be more specific, its a bunch of knocking noises and when raising or lowering using floor jack. sometimes a slam hard enough to make the dirt caked to the undercarrage fly off.
Old Aug 25, 2002
VNlilMAN's Avatar
The Standard One
small knocking noises is normal, a big slam, making dust fly isnt... how exactly are you taking it off the jack stands? i never used jack stands so i dont know the proper way to use them but even then i'm sure it wouldnt slam cause the springs/shocks bounce. well maybe its blown shocks and what your hearing is the shocks bottoming out on the bumpstops. is your car lowered? try jacking up each corner one by one and see if it makes that noise on all 4s
Old Aug 25, 2002
1955's Avatar
cool,just jack up the car and place a jackstand next to the point where the jackin point contact the frame/chasis then releas the jack slowly and the car will be very safe (on a level ground of course),as to the question from Likeweee... we can stop the guessin game on the slammin noice and let a good alignment shop check the componets out.good luck
mistermenphis22
Jul 13, 2015 04:43 PM
cgavin1
Jul 7, 2015 07:10 AM
BootyDo
Jul 7, 2015 06:06 AM
robbie374
Jul 7, 2015 02:56 AM
GH04si
Apr 15, 2015 08:13 PM
