Here we go again
Old Apr 27, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Here we go again
OK now the new engine is in and the car starts up just fine the first time...all fluid levels are checked then double checked and filled to perfect....i drive around the block about 1 half mile and then bam it dies at idle just like it did before with the other engine...honda claims it was compression causing the same thing in the first engine (which only had 50k miles on it) and now this one is doing the same thing with only 15K what the hell is the deal this engine was shown to have perfect compression across the board when i picked it up and now same damn thing anyone have any idea what the hell is going on with this piece of ****.
Old Apr 28, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
its your ECU, go down to you your local junk yard and pick up a new one.
Old Apr 28, 2004
Really how do you know this
What makes you think it is the computer Honda says it isnt...no offense i dont mean to say i dont believe you i just want to know exactly what happened
Old Apr 28, 2004
KaZeLL's Avatar
think about it for a sec, you pulled the complet motor out and replacedit um what else is there left besides a few sencors, and the ecu and gas lines...umm nothing...heres one if you know of a bud with the same car, barrow his ecu and take it for a spin see if the prob persis...if not then there it is...over here at a junk yard the ecu is about 150 bucks...not a big loss...if it doesnt wrk then you have an extra one for reprogramming(chip)...but sometime hoda doesnt know what the **** there talking about...i took my car back a dozen of time kuz the car keept bogging on me at 4000 rpms...they told me that they couldnt understand the code the ecu was throughing out turns out that car had no oil in at all....no one botherd to do a complet check at honda...huh..well now i find out that every 2 months my car needs 3 qrts of oil cuz the motor burns it up...
Old Apr 28, 2004
my oil is fine just filled it up about 10 minutes before the engine was started for the first time but it did bog down at about 4 grand and does all the same stuff so ill check it out...can i use the ex ecu for the test i have an hx with an ex motor
Old Apr 28, 2004
KaZeLL's Avatar
not to sure on that one bro, i think you should be fine as long as it has vtech, i mean the ex is only full power with roof...just add ons give it a try...what could it hurt...
Old Apr 28, 2004
I see i see ill give it a shot tomorrow and go from there...ill let everyone know what happens
Old Apr 28, 2004
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
if you have a CAI make sure that it isn't taking in water somehow... losing compression is a symptom of hydrolocking sometimes. just throwin in my 2 cents.
Old Apr 28, 2004
KaZeLL's Avatar
ya be sure to post results, i would like to know myself
Old Apr 29, 2004
Umm ok havent been able to locate an ecu yet but still trying and i know its not hydrolock
