removing stock headlights
Old May 10, 2004
Misfit741's Avatar
Misfit741 is an unknown quantity at this point
Do you absolutely have to remove the front bumper to get the headlights off? Seems like a lot of work to put in new headlights.
Old May 11, 2004
cheukkin's Avatar
cheukkin is an unknown quantity at this point
You don't really need to but I will take the front bumper off easy as a piece of cake.
Old May 11, 2004
prawdigy's Avatar
prawdigy is an unknown quantity at this point
I've taken off the headlights a few times and it'd be really hard to take them off without removing the bumper, cuz there are the brackets connecting the headlights to the car.. its right under the headlight, its a 10mm, and the bumper is easy to remove.
Old May 11, 2004
Mr.Modify's Avatar
Just take it off....don't be lazy. It's not that hard it'll make things much easier!
Search to man!! This has been covered numerous times !!
Old May 11, 2004
Kairi's Avatar
Kairi is an unknown quantity at this point
Actually, if you just let the bumper hang you can reach under the side right under where the fender hangs and you can unscrew the side screw that holds the under bracket, then you can get a long extension and unscrew the one that olds the under bracket closer to the grille. It's REALLY easy if you take off the upper grille when you do it. I have heard people with altezza grilles have it easier. In all honesty, you can take the headlights off without removing the bumper, but realize that if it's your first time.. you should just for the experience.
Old May 11, 2004
pr4life36's Avatar
pr4life36 is an unknown quantity at this point
thats what i did
Old May 11, 2004
Mr.Modify's Avatar
okay but why just stop at letting it hang from 4 little clips? just unclip them and take it off ....wow!!
Old May 11, 2004
Misfit741's Avatar
thanks guys... maybe i will take off the bumper just for a learning experience.
Old May 11, 2004
nme3's Avatar
JDM wannabe
yah i just let it hang, those clips underneath always breaks and it pisses me off
Old Jul 2, 2004
dru106's Avatar
ThE CoRRupToR
Yup!! Those clips are a bitch to take off and if u break em u can goto the dealers and get some for only $3 EACH!!! YEAH!! Just for only 1 clip its $3!! Its insane!!! . I just let those 4 clips hold the bumper.
Erndog81
Oct 31, 2015 03:01 PM
stryder12
Jun 30, 2015 08:33 PM
shaejb15
Apr 26, 2015 07:44 PM
ilgnay
Apr 26, 2010 11:53 PM
