Throttle DIY trouble
Old Feb 7, 2003
01EMCVC's Avatar
01EMCVC is an unknown quantity at this point
is the throttle cable DIY possible on a 01 civic lx sedan, I attmepted it and was unalbe to loosen the locknut because of the bracket holding the cable. any info is appreciated. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 7, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
I don't understand the point anyway. There is a little slack at first, but its not like it will open the thorttle anymore when its wide open..... I'd just leave it alone.
Old Feb 7, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Quote
[hr]Originally posted by: Friedrice
I don't understand the point anyway. There is a little slack at first, but its not like it will open the thorttle anymore when its wide open..... I'd just leave it alone.[hr]
It is for better throttle response.....instead of you picking up slack first then the tbi opens, there is no slack to pick up.
Old Feb 7, 2003
VTECHUNTER's Avatar
VTECHUNTER is an unknown quantity at this point
i performed this diy a while back...when you take the slack away from the petal, when you hit the gas to the floor, when the petal is on the ground the throttle plate is open to 100%...when you take the slack away, the throttle plate will hit 100% BEFORE the petal hits the floor...then when you push the petal farther, the cable will stretch, i broke mine 2 days after doing this diy, my local honda dealership replaced the cable and tld me it was because i took all the slack away, you can take SOME of it away, but beware you can take too much out, and then your screwed! im not sure if im the only one to brake the cable, but thats my 2 cents.
Old Feb 7, 2003
djmota's Avatar
thats exactly why i have not done that mod.
Old Feb 7, 2003
Elite's Avatar
Elite is an unknown quantity at this point
Quote
[hr]Originally posted by: VTECHUNTER
i performed this diy a while back...when you take the slack away from the petal, when you hit the gas to the floor, when the petal is on the ground the throttle plate is open to 100%...when you take the slack away, the throttle plate will hit 100% BEFORE the petal hits the floor...then when you push the petal farther, the cable will stretch, i broke mine 2 days after doing this diy, my local honda dealership replaced the cable and tld me it was because i took all the slack away, you can take SOME of it away, but beware you can take too much out, and then your screwed! im not sure if im the only one to brake the cable, but thats my 2 cents.[hr]
its called test it out and make sure everything works fine before driving lol. [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/face-icon-small-nono.gif[/IMG]
Old Feb 7, 2003
APRboy's Avatar
APRboy is on a distinguished road
Yes it is possible. I have a 2002 sedan and i did it. Better throttle response.
Old Feb 9, 2003
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
i did this, and i tightened mine too much, but luckly my line didnt break.. but i think it stretched out a lil cuz when i try to loosen up the slack, theres a lot more slack than there was before
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
