Need ECU chip info
Old Feb 25, 2003
Mikee's Avatar
Mikee is an unknown quantity at this point
Need ECU chip info
i need some infromation on ecu chip.. does anyone have sites i can go or tell me how i can get mine programed..
Old Feb 25, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
Jet Ecu right now is the main one to get it reprogrammed, as for piggy backing the ecu I believe you can only do that to modify the fuel curve, not definite though
Old Feb 25, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
yah, and jet takes a week to reprogram and getthe chip back out to you. so you without a car for like a week
Old Feb 25, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
do a search... this has been discussed.
It only took 1 day for mine to be re-programmed and back in my car.
Old Feb 25, 2003
Mikee's Avatar
where can i go to do my research. i dont wanna look on web for like hours so can u tell me a site.
Old Feb 25, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
there is a search function in the forum is what they are trying to say..... www.jetchip.com is Jets site
Old Feb 26, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
If you don't want to go through all of the reprograming stuff you can buy a Venom chip that takes about 30 minutes to hook up and gives you a big Horsepower gain (especially if you have other engine mods). I'm not 100% sure but I think its close to the same amount of HP gain as the Jet chip They are kind of expensive but theres only 4 wires that you have to hook up, positive and negative on the battery, one wire on the MAP sensor, and one on the TPS Sensor, making it pretty easy and quick. I've done a ton of research to find the best price and heres the site that has the cheapest price for it, theres also more information on what it does on it also... http://store.yahoo.com/dpstore/ven400percon1.html?source=overture
Old Feb 26, 2003
Mikee's Avatar
whats the difference between computer upgrade and jet v-force... is up grade better or is it the same[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 26, 2003
Mikee's Avatar
did anyone get venom 400 before cuz i neverheard of it. i would get it but first i need other peoples advise on it. also adding wires to the battery, wont that make ur are drain more battery?? venom 400, chip upgrade, jet v-force which one is better or whats the differnece in all 3??
Old Feb 26, 2003
are you talking about the differnce between the Jet chip that they soder into your comptuers ECU or the add on chip that dosent require you to send in your ECU?
Old Feb 26, 2003
I have had mine hooked up directly to my battery for about 6 month's now and it hasnt done a thing to my batter because it only kicks in when you have your foot on the gas 1/3 to 1/2 of the way down, therefore it dosent use much if any power when your car is off, I like it because whenever i go into Honda to have work done on it Its easy to take out so it won't void my warenty, but if you have the JET chip soddered onto your ECU im willing to bet that the Dealer will say that it voided your warenty because you cant take it out everytime you take it in for service, and then you would be screwed.
Old Feb 27, 2003
cdmx's Avatar
CiViCrAcEr2003, how much is the one you can add on and take off? And what is the difference between the soldered chip?
Old Feb 27, 2003
The Venom400 chip is about $270 at http://store.yahoo.com/dpstore/ven400percon1.html?source=overture and im not exactly sure what the differnces are between the venom and the jet chip, I would assume that they both do about the same. The venom chip just monitors 2 sensors under the hood and changes there output to give the car more power. It says that it can give up to 25% more horsepower and I think that depends alot on what else you have under your hood, I just have the chip and a cold air intake and its a very noticable differnce from stock.
Old Feb 28, 2003
Mikee's Avatar
was the venom diy or you took it to a shop. i think i will get the venom cuz it is cheaper then the chip. and the chip u cant get it back to stock. what the difference between vtech controllor and venom?
emich
May 29, 2016 06:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
