TYC projectors... pls help...
Old Feb 7, 2003
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
i need all your help please.
the left projector isn't working...
the bulb is not blown, cause when i touch the back part of it, the light turns on...
seems to be wiring...
Old Feb 7, 2003
skipbarber's Avatar
you pretty much just solved your own problem..try making stay on with solder..if your not comfortable doing that, just return them or exchange them from where you got them.
Old Feb 7, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: SkipBarber
you pretty much just solved your own problem..try making stay on with solder..if your not comfortable doing that, just return them or exchange them from where you got them.[hr]
i would return them if i were you IMO, obviously everything else is in order
Old Feb 7, 2003
blazed870's Avatar
blazed870 is on a distinguished road
My projectors were the same way. I took it off and one of the wires that led to the bulb wasn't connecting all the way cuz the sleeve it was in was preventing it from touching the metal. I slid the sleave up and tightened the wire and my lights have worked fine since. I wish I could explain it better cuz I know that explanation is crappy, but maybe if you look at your projectors you will know what i am talking about.
Old Feb 8, 2003
FlippedOut's Avatar
Quote
[hr]Originally posted by: blazed870
My projectors were the same way. I took it off and one of the wires that led to the bulb wasn't connecting all the way cuz the sleeve it was in was preventing it from touching the metal. I slid the sleave up and tightened the wire and my lights have worked fine since. I wish I could explain it better cuz I know that explanation is crappy, but maybe if you look at your projectors you will know what i am talking about.[hr]
thanks.
worked like a charm[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 12, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
does anyone remember what each screw does wen adjusting the projectors? like which screw movedit left/right/up/down etc?
thankx
Old Mar 10, 2003
SDE's Avatar
SDE
SDE is an unknown quantity at this point
I've also been having problems with my TYC Projectors. Seems like every once in a while one of my lights is out (both sides), but only one at a time. I have fixed it at times, just by moving the wiring harness where its connected. However, the last time I tried to move the wiring harness around it did not work. So i pulled the lights out and tried shuffling the lights from my hi-beam to low beam even though the low beam bulb did not appear blown. It still did not work, but that was before i actually put it back in it's socket. Before changing the bulb again i stuck the bulb into the socket without clipping it in, it worked but i was determined to find out the cause of the problem so i pulled it out again. As soon as the metal end of the bulb lost contact with the metal housing of the TYC Projector it shut off. It seems to me like it's got something to do with grounding. If any of you are having problems with your bulbs I'd try this out. I am yet to prevent it from happening but any ideas would be appreciated.
*All of the lights worked after I swapped them around as well, but not for long.
Old Mar 11, 2003
Dr5D's Avatar
sounds like lots of people are having problems with their TYCs and i havent even installed mine yet!!!
i am intrested in knowing how to aim them tho, i have had that darn problem twice already[IMG]i/expressions/face-icon-small-nono.gif[/IMG]
Old Mar 11, 2003
SDE's Avatar
SDE
anyone try this yet?
Old Mar 11, 2003
SDE's Avatar
SDE
BTW mine are burning out now they are called XD5 Super Whites (Quartz Glass). Some crap i bought on ebay listed as H.I.D. 5000K (12 Volts, 100 Watts) heh. Anyone have any good experience with any of these aftermarket Hyper-White bulbs that do well in the TYC housing? Please list any type you've had no trouble with, thanks
