Injen CAI install advice
Old Feb 22, 2003
rasper's Avatar
rasper is an unknown quantity at this point
I am installing an Injen CAI on my 2k1 EX sedan tomorrow and I was wondering if anyone had any advice or insight to offer. This will be the first mod to my car, and I haven't ever modded any of my previous cars, so any advice will be helpful. I did search and found some tips, plus the instructions included seem easy enough to follow, but I would like to hear from the members out there.
Thank you in advance.
Old Feb 22, 2003
Vinh's Avatar
umm....make sure u know where each parts go not just cai but any mods
and have some wut idea of what you are doing and get someone wit experience
Example: i took off the screw to the brake fluid (to paint my calipers) and it poured everywhere in the garage
and i had no brake pressure .....i drove 3 miles to the repair shop wit no brakes (down shift to slow down).....50 bux to repair....
Old Feb 22, 2003
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
I have a verrrrryyyyy good idea for you.
If you live in a colder climate then you will appreciate doing this the first time.
When you have your bumper off and are relacing that 10mm screw/bolt that holds the grounding harness to your chassis, you are going to attach this black rubber bumper thing. BUY yourself either galvanized or Stainless Steel washers that match the OD and ID of this bumper, 2 of them total.
Take that grounding harness and flip it over so that the little bent tab faces outward isntead of inward.then place teh harness against the chassis, followed by a washer and then that rubnber bumper. TORQUE the bumper down as much as you possibly can and then torque it down some more. then place a second washer on teh other side of the rubber bumper followed by teh lower CAI extension and the supplied washer and nut then torque them down as much as possible after fitting the intake into position.
Also, if you plan on adding sidemarkers later on, this is the perfect time to splice into teh headlight wiring and run your extension leads up into the engine bay and leave taped out of the way for now so you wont have to remove your bumper again later on. Definitely make sure that you have at least 3 feet of wire per side if you are putting them behind the wheel well under your rear view mirrors.
Hope it helps.
Old Feb 22, 2003
Quote
[hr]Originally posted by: Vinh
and i had no brake pressure .....i drove 3 miles to the repair shop wit no brakes (down shift to slow down).....50 bux to repair....[hr]
Okay, not trying to flame but what were you thinking taking the calipers off to paint them? Have you ever seen a body shop take panels off a car to paint them? You just have to mask off all teh areas you dont want painted and then spray JUST the calipers. OR the easiest way to do this is either get a brush on kit or if you cannot get a brush kit, find a 5oz dixie cup or similar and spray abotu 1/4" of paint into the cup from teh spray can (Outside preferable, tons of mist everywhere from this) and then just use a brush to brush on the paint, It will actually work all teh same as spraying on except you can take your time and not worry about spraying other parts on accident. I didnt even mask off my calipers and drums when i painted them and they came out great.
Old Feb 22, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
just take your time on the installation and you dont really need to take off the bumper unless you absolutely want to.
INJEN
Old Feb 22, 2003
BooHa's Avatar
BooHa is an unknown quantity at this point
Putting an intake on is really easy. My advice is have a friend help you. And don't lose and parts![IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Feb 22, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
I would defenitely advise you to take off your front bumper. First, you will have an easier time getting the CAI in place. Secondly if you ever do more mods in the engine area/ lighting you will have a better understanding of the engine bay making the next time much easier.
Old Feb 23, 2003
rasper's Avatar
I finished the install and I couldn't be happier with it. It took me a while, but no problems. I just took it for a test drive and I can feel an improvement in acceleration, plus it sounds nice when I hit the gas. Thank you again to all who posted advice... except for Snakes. What happened there?
JohnnyBxo
Nov 12, 2015 03:04 PM
trevor
Nov 16, 2001 05:02 PM
trevor
Nov 15, 2001 05:59 PM
Daniel420
Nov 9, 2001 08:36 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
