o2 senor help ASAP!!
Old Feb 27, 2003
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i am trying to hook up my autometer air fuel guage. which wire on the o2 sensor is the signal wire. there are 2 white wires, 1 gray and 1 black. did search, and nothing. thanks, wesley
Old Feb 27, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
if i am not mistaken its the gray wire.
INJEN
Old Feb 27, 2003
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Whatever you do...
DON'T CUT THE RED WIRE!!!!!!
Old Feb 27, 2003
jwcardy's Avatar
hahah, funny todd, a man in need and all you can do is make fun of me
Old Feb 27, 2003
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Yes, I have to second that about it being the grey wire.
White (2 of them) = Power leads
Black = Ground
Grey = Variable signal wire.
Side note: This wire is very sensitive, it only runs a whopping 0v to 1v signal dependant on the amount of trace oxygen in your exhaust gasses. DO NOT cut this wire to tap into it. Use a t-splice or strip a small section of insulation and use a "rabbit ear" method to splice your lead into that wire.
Old Feb 28, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I think you have it backwards!!! The BLACK is the signal wire, look at this diagram... its easy to figure it out....
black is signal
grey is ground
2 whites are for heater control. Don't post wrong information as you'll definitly screw up someones vehicle!!!
Old Feb 28, 2003
jwcardy's Avatar
yeah, thanks. i was just getting on here to say that it isnt the grey wire. it the is black wire inbetweent he plug and o2 sensor. if you connect after the plug, it is the white wire.
why would honda make a grey wire a ground when black is univers for ground???
Old Feb 28, 2003
AEMcivic's Avatar
I think the Japanese are ****in wit us!!
