torque?
Old Feb 14, 2003
JAG609's Avatar
JAG609 is an unknown quantity at this point
torque?
if by some miracle that we did the K20series drop, H/I/E, turbo, intercooler, nitorus, ect......would our car just spin...and spin....and spin.... how can we get the torque to match it?
Old Feb 14, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Well first off, that is going to cost you a fortune. 2nd you will not need a header if your running forced induction. Im not sure i understand your question on how to get the torque to match it... torque is what will be spinning and spinning your wheels. And if you are at that point you will break an axle. So if you want to get the power to the ground your going to need a heavy duty clutch, axles, and slicks if you want it to hook. Hope im pointing you in the right direction. Good luck.
Old Feb 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
Quote
[hr]Well first off, that is going to cost you a fortune. 2nd you will not need a header if your running forced induction. Im not sure i understand your question on how to get the torque to match it... torque is what will be spinning and spinning your wheels. And if you are at that point you will break an axle. So if you want to get the power to the ground your going to need a heavy duty clutch, axles, and slicks if you want it to hook. Hope im pointing you in the right direction. Good luck. [hr]
word.
EdGasket
40
Nov 27, 2015 11:11 AM
rovafa2002
Sep 28, 2015 06:57 PM
WaryDriver
Aug 16, 2015 11:22 AM
logsplitter1
Aug 9, 2015 09:32 AM
breanna_17
Jul 21, 2015 04:01 PM
