what paint do you guys use for your black housing?
Old Feb 22, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
What paint do you guys use for black housing your headlight and where do you guys buy them at? thanks
Old Feb 22, 2003
amhtown01's Avatar
i haven't done it yet, but i'm thinkin on flat black, or black metallic. I'm gettin mine at my local Kragen Auto Parts (hook up)
Old Feb 22, 2003
midvis's Avatar
Vic On Dubs
midvis is an unknown quantity at this point
I just used a regular can of gunmetal paint. You dont have to get the high heat paint or anyother special kinds. Check out mt members rides page and I believe you can see them there. They came out great.
MIDVIS
Old Feb 22, 2003
7thGenerasianCivic's Avatar
I think any brand will do...it depends if you want it to be glossy, semi, or solid. Also make sure you use high temp paint (I used 500 degrees) Don't forget to buy clear coat too.
Old Feb 22, 2003
andyman97's Avatar
Turbo Guru
Depends on how good of quality you want and whether or not you want to ever have to do it again. If you don't care, use a spray can. If you don't want to have to worry about it again, get some actual exterior paint and have them sprayed. Napa sells paints too, that's where I buy mine.
Old Feb 22, 2003
fraga's Avatar
Wicked Moderatuh
I just used some High Temp Glossy Black paint followed by some Clear Coat...
Old Feb 22, 2003
Samari's Avatar
Just to play it safe you might want to use 500 degree engine paint.
Old Feb 22, 2003
TeLLy's Avatar
Yes, it's an Acura EL
I gunmetalled with Duplicolor wheel coating (graphite). I used pretty much a whole can on the housings. Looks pimp.
Old Feb 22, 2003
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
i had my body shop paint them the color of my car when i had the car painted custom black w/ blue pearl (tons of blue pearl) not like NBP...
and they look sweet i still have them w. my new gun metal paint..
dave
Old Feb 22, 2003
cdmx's Avatar
It looks tight with just semi gloss black, heres a pic without the cover and back on.
If your wondering what to use to cover up what you dont want to paint, use the vanilla colored masking tape....it doesn't stick to much
Also if you really want it very glossy like the car paint, this is going to take several coats of black and A lot of clear coat, IMO it looks fine with just 3 coats black 3 coats clear... One thing i did mess up is i let them dry in the garage where its dusty and if you look close you can see the dust in the paint... remember this
Old Feb 22, 2003
dragoon's Avatar
i used duplicolor flat black engine paint. no gloss here, i think it's ghEy
usajags84
15
Aug 19, 2015 03:12 AM
stryder12
Jun 30, 2015 08:33 PM
cmart1209
May 29, 2015 04:52 AM
wsking77
Aug 29, 2001 05:34 PM
