Adjust Throttle Cable??
Rep Power: 0 ![civichx81 is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
like when you tap your gas pedal,you accellerate a little quicker. the factory setting is for those granny drivers, so they dont accidently rear end other cars. hope that helps.
Rep Power: 0 ![Pedrito is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
sup guys i too have a ? about the throttle cable....where exactly is the throttle cable and what do you exactly do to adjust it...i have basically everything on my car myself and i want to do this as well i just need to find out exactly what to do...can one of you that has done the throttle cable adjustment specify a little more than the DIY or is that exactly how ur supposed to do it??? like the DIY says??? help me out thanks
Rep Power: 0 ![DarkCivic is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
Look right next to the throttle body- you'll see the metal lever that pushes the throttle up when the line is pulled. Just get an adjustable wrench and tighten it so the lever is flush with the throttle. Do do it too much or you'll idle high.
Rep Power: 0 ![kFanghe is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
I still don't see what the point is. If you have an automatic, fine it makes sense, but a manual??[IMG]i/expressions/face-icon-small-confused.gif[/IMG] why bother
I'm bigger than you.
Rep Power: 295 ![DannyK35 is a name known to all](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
![DannyK35 is a name known to all](https://www.civicforums.com/forums/images/reputation/reputation_highpos.gif)
Don't waste your time adjusting it, it won't make a difference....maybe in your mind it will, but it doesn't make a real difference. Now if you REALLY want increased performance, slap on some stickers baby!!!
Rep Power: 0 ![Speedracer32 is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
<< Don't waste your time adjusting it, it won't make a difference....maybe in your mind it will, but it doesn't make a real difference. Now if you REALLY want increased performance, slap on some stickers baby!!! >>
that's right
![Smile](https://www.civicforums.com/forums/images/smilies/smile.gif)
![Thumb Up](https://www.civicforums.com/forums/images/smilies/thumbs_up.gif)
velozp
12-13-2015 11:28 AM
IronFist
09-25-2015 07:13 PM
Bricoleur
09-09-2015 12:30 PM
