New...Had a quick Question
Old May 1, 2002
31R's Avatar
31R
31R is an unknown quantity at this point
I new to this site, actually i've been watching it for awhile and decided to join. Anyways i searched on here about my question but could'nt find an answer. Well i just installed my new reverse el gauges. I was careful to not mess with needle but once i was done installing it everything worked fine except that the needles get stuck. My rpm and mph needle gets stuck while i drive, now what does this mean? Does it mean i have to get a new gauge cluster. Thanks if you reply.
Old May 1, 2002
Kore's Avatar
Kore is an unknown quantity at this point
I have the same problem with my gas meter and temperature too! although I got them installed by some shop and they didn't do it right...bastards
Old May 1, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Check to make sure they are sitting right, sometimes they can pull away from the mounting surface and the needles get caught on them. You should be able to check this yourself if you feel comfortable taking them apart, or have a shop look at them. As for Kore I would be going back to the shop and have them fix it right.
Old May 1, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Just put some doublesided tape under the new gauges. I had that problem too and the tape fixed it right up. HTH
-Kre
Old May 1, 2002
robbclark1's Avatar
Retired suspension supermod.
my tach does the same thing. I was told just to make sure the guages were pressed all the way down.
Old May 1, 2002
revitcivic's Avatar
revitcivic is an unknown quantity at this point
Yeah, the guages only need to come up like a centimeter in oder for them to get the needles stuck.
I notice that what stops the needle is in the center, right around the hole.
Slap some 2 sided tape and you should be fine.
Personally i used a drop or two of crazy glue(i wanted a permanent install).
Old May 1, 2002
31R's Avatar
31R
Thanks everyone for your help....I'll take a look at it today.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
