Non-Civic Help Please....
Old May 10, 2002
Deu's Avatar
Deu
Deu is an unknown quantity at this point
I just baught a truck for 100$'s and it was running as well as could be expected untill yesterday. When I try to start it, it just wouldnt start. The voltage was low until the car started so I replaced the battery. Well now it has 12v when I turn the key, but when I try to start it just clicks...and clicks...and every once in a while turns over but very very roughly....is this the starter? Or do I have more serious problems?
Old May 10, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Considering you bought the truck for $100, it probably has more serious problems.[IMG]i/expressions/laugh2.gif[/IMG]
Old May 10, 2002
ayzan's Avatar
ayzan is an unknown quantity at this point
It's the starter. The clicker you here is the solenoid pushing the gear in the starter to the flywheel. The solenoid is working, but the starter isn't rotating which is why your truck won't start. Replace the starter, but you'll probably get more problems down the line since the truck was only 100 bucks.
Old May 10, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
definately the starter motor
Old May 10, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
might want to check the battery cables too, if they are bad it will act just like a bad starter. If you're lucky it will be the cables--they're cheaper.
Old May 11, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Same thing happened to my truck a week ago.. crawed under my truck and noticed my starter was hanging by 1 screw
Old May 11, 2002
DJ's Avatar
DJ
DJ is an unknown quantity at this point
CHECK ALL POINTS IN THE CHARGING AND STARTING SYSTEM WHERE WIRES ARE BOLTED OR GROUNDED....CLEAN THEM UP. THEN TRY STARTING AGAIN......
gearbox
Nov 2, 2008 06:30 PM
TRIZ
Jun 10, 2008 06:12 PM
gearbox
May 4, 2008 08:33 PM
