Catback Exhaust Install Help
Hello all, I have some questions regarding the installation of a catback exhaust.
I bought a used catback off someone else and it arrived early yesterday. He included the used aftermarket gaskets but they aren't in that great of a shape (the edges seem worn and flaring like a a loose deck of cards). Okay on to my questions:
1) My oem exhaust is quite old and rusted. I tried removing the nuts off of the bolts and had an extremely hard time doing so only to give up after 20 minutes. I already tried soaking with wd-40 and ratcheting the hell out of it, but it wont budge. Any ideas on how I can remove these stubborn nuts? The nuts and bolts will be replaced, but I dont want to damage my oem exhaust.
2) Is it a good idea to get new gaskets for the exhaust? What is the worst thing that can happen with reusing gaskets?
3) Has anybody reused exhaust gaskets? Any troubles?
Search and Learn
1) Try to use braker bar. In the worst case, You might have to go to local shop and let them heat up the bolts to get them off.
Then replace with new hardware.
2)It is good idea to get new gasket. You might have leak between cat to b pipe. or B pipe to rear section muffler.
3)I reused donut gasket for Cat to B pipe and no problem at all.
Is an exhaust leak dangerous?
throw out the wd-40 and buy yourself a can of pb blaster. spray it on, try to remove bolts, it works really well so they should come off, if they dont then just keep on sprayin and go for a drive or somethin, they will eventually budge
Damn, I dont have any airtools, you think I could buy one from sears or something then return it after I get them off? lol
What about those nutsplitters? how do those work?
Originally Posted by ctx66
shouldnt need airtools to remove exhaust bolts. have you tried kicking/pushing the wrench with your foot?
Got it installed, love the deep hum......
I got my bolts/nuts loosen for free at midas, the mechanic was way cool. I did the install today and forgot to take my car out of gear when I started it (I wasnt sitting inside, I was just using my hand to hold the clutch down, started the car and let go, BAM! I jammed the two jackstands into the jack points. Hurried up and jacked up the car to yank out the jackstands out of a fresh dented hole into the jack point.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
