engine error with de cat hi flow
Old Jun 22, 2004
scottwillcocks's Avatar
scottwillcocks will become famous soon enoughscottwillcocks will become famous soon enough
Hi ,, can any one help me,, i have just installed a megan racing hiflow cat pipe and after a day the engine[ecu] light has come on.... after taking it to honda they tell me its because the ecu is getting an incorrect reading from the cat sensors,,, cat inefficient,,,
is there any one had the same problem??
is there any way around this??
honda say the sensors are ok and to put the cat back on!!!!
Old Jun 22, 2004
MK3Brent's Avatar
MK3Brent is an unknown quantity at this point
There are O2 sensors in exhaust systems.... clear your codes...it should be fine, or else your ECU will continue to be in LIMP mode.
Old Jun 22, 2004
how do you clear the codes?? i hve unplugged/plugged the ecu fuse
Old Jun 22, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
you have to either use O2 simulator or a real hi-flow cat...
Megan Hi-flow cat = Megan Hi-flow resonator
Old Jun 22, 2004
what is an02 simulator? where does it fit and where can i get one please??
Old Jun 30, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
I have the same Problem with my high flow cat!
Old Jun 30, 2004
i have just installed a simulator from casper electronics,, its a small box with a male and female plug that goes in line with the post cat sensor.. the plug is located at the bottom left rear of the engine bay under the air box / intake.
its way down , but better than getting under the car, just unplugg the sensor and put the simulator in then plug then plug the sensor into it..
i dissconected the battery as the light didnt go off on its own,, just hope it stays off.....
scott
Old Jun 30, 2004
lid6662's Avatar
Ya I would buy one if I knew It would take off the check engine light. Also I was worreid that having that on would maybe hurt the fuel maps or decrease fuel. WHen I first installed the high flow cat it came on after about 20 or so miles...
I have a 03 ex with Highflow cat /Header and /cat back
I looked it up but theres not that much info about the elimintor working....
Old Jun 30, 2004
well we will see i will let you know if my light comes back on
Old Jul 18, 2004
lid6662's Avatar
Bump any info yet.......
Old Jul 18, 2004
its fine , no light ,,, and the car drives well.
i say get one
Old Aug 19, 2004
lid6662's Avatar
Still no Light my lights now goes on and off every 100 miles or so....
Also How much was your o2sim?
Old Aug 19, 2004
518's Avatar
518
518 is on a distinguished road
you are correct.
Im glad I didnt get a CEL with the RandomTech high-flow cat with my OBX Header, RandomTech hi-flow cat, and magnaflow cat-back set-up.
Old Aug 19, 2004
streetglower's Avatar
Mine came on when I had my high flow cat put on, but I found out it was due to the idiots at the muffler shop putting the o2 sensor in the front of the cat, when it was supposed to go in the rear.
Old Aug 19, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Hey scott can you post a link to the company you bought your part from.
Old Aug 20, 2004
i think its www.casperelectronics.com
or www.casper-electronics.com
Old Aug 20, 2004
lid6662's Avatar
The site is under construction
Old Aug 20, 2004
1320Racing's Avatar
1320Racing is an unknown quantity at this point
I have no problem with my HP Header and Megan High Flow Cat with the Big Josh Racing 02 sim sensor you just have to make sure you hook it up good
Old Aug 23, 2004
sorry this is it..... http://www.casperselectronics.com/
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
ShoGuN
Canada West
Jan 6, 2002 02:41 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
TaiChi
Dec 17, 2001 09:09 PM
